I can’t find on HACS or i’m missing something?
I’ll try the manual install.
LE: It’s working for monitor devices, but all eth0,eth1,eth2,eth3,eth4 are off. I have all 5 ports online.
Need to check it, also not working for me
fixed, please take latest
It’s working weird.
I got connected on eth0 but when I click on history i get disconnect.
Could it be that it changed 3 minutes ago and the history is for 24 hours?
New version released, focused on improving the way the component is loading, unloading and discover new entities (sensors and device trackers).
the main issue as reported in the past was that once changing the entity_id / name it will return to the original after restart.
another issue that caused by the way it was handled, upon changing the options (settings) - it took few seconds to present the new entities and sometimes it happened only after restart.
In that version, the entity_id, name will remain as manually set and changes of options will take place immediately
Can’t find it in HACS. Any other way to install?
Any chance of this development becoming part of official HA integration?
Upsides except for code review would be to allow people like me (for stability and reliability I tend not to use customs).
Would love to support if needed…
Added it in the README
Implemented enhancements:
Fixed bugs:
Nevermind, works fine with custom port
Just installed via HACS however when I go to add through integration and choose Edge OS it just “flashes” and goes back to selection list. Any idea what I maybe doing wrong ?
can you post the log?
thanks
Looks like a reboot of host fixed the issue and I am now able to integrate. Now getting system status, uptime and known devices.
How do I get to “Edit Options (options for Edge)” to select interfaces to monitor ?.
Thank you for your help.
remove the NONE checkbox, more details available in the README
All sorted.
Many Thanks.
Are there plans to add Edgeswitch support or should it already work?
I don’t know as I don’t own that device, but if it’s based on EdgeOS, it supposed to…
Hi bar, thanks for you great job!
I have been using your project for a long time and I like it a lot.
Recently, I had to reinstall my Home Assistant and decided to install the latest version of your project through HACS.
I was able to install it easily, but device_tracker didnt work correctly. It is always displayed not home, however when clicking on the card it is informed that in the connect attribute as true.
Like this:
Thanks, I’ve had a go and it does not connect. Doing a bit of digging and it looks like I’m mistaken and the Edgeswitches don’t seem to be running EdgeOS.
