Custom Component: Flightradar24
v1.32.1 Released
Changelog
The flightradar is still acting like a jojoba!
Doh
v1.32.4 Released
Changelog
  • Updated FlightRadarAPI client that fixes 403 Forbidden error caused by Cloudflare bot protection
Updated to this version but still problems :
Logger: custom_components.flightradar24
Bron: custom_components/flightradar24/coordinator.py:97
Integratie: Flightradar24 (documentatie, problemen)
Eerst voorgekomen: 13:53:07 (188 gebeurtenissen)
Laatst gelogd: 14:52:17
FlightRadar24: HTTP Error 429:
FlightRadar24: Failed to perform, curl: (28) Operation timed out after 10002 milliseconds with 0 bytes received. See libcurl - Error Codes first for more details.
Thank you
v1.33.0 Released
Changelog
  • Updated translations for different languages
  • Added Helicopters in area sensor
  • Live Airplane Photos on the Map: Tracked flights on your Home Assistant map will no longer show a generic icon or text initials! The integration now passes the aircraft_photo_small URL as the entity_picture, displaying the actual photograph of the plane moving across your map.
  • Added Enabling/Disabling auto-cleanup of landed tracked flights. That automatically removes flights from the "Additional tracked" list once they arrive at the gate
  • Added event flightradar24_tracked_arrived_gate. Fired when a tracked flight removed from the tracked list.
  • Added flight field aircraft_icao_24bit - Unique aircraft ID
  • Added Custom Map Tracker Naming Style: Added a new configuration dropdown allowing you to choose how flights are labeled on your map. Options include:
    Callsign Only (e.g., KLM1412) - Default
    Callsign + Route (e.g., KLM1412 (CDG - AMS))
    Registration + Route (e.g., PH-BXE (CDG - AMS))
For these updates thanks to @malosaaa 3 Bundled feature requests (#198,#171,#199#) by malosaaa · Pull Request #218 · AlexandrErohin/home-assistant-flightradar24 · GitHub
v1.34.0 Released
Break change!
  • Removed sensor Helicopters in area!
Changelog
Does the Lovelace Airport Card Still exist in 2026 if so can one tell me where to find it?
The Lovelace Airport Card wasn't an actual card by itself. Rather, it is an example of code to use on your dashboard. The "official" card is shown in the docs at the bottom. Lovelace Airport Card
thanks sort of figured it our
