Custom Component: Hubitat
Yes
Did you restart HA after installing the integration?
Yes, do I restart the whole docker?
No, you should just need to restart HA (like, from Configure -> Server Controls -> Restart).
I had to restart the whole container, that fixed it. Excuse my ignorance, I don’t even know what a docker is really. I bought this setup,lol
Not a problem – there’s a lot going on with an HA setup. :slight_smile:
Tell me about it stephhacks spent like 8 hrs throughout a day helping me. Literally one hr after setup, the whole thing crashed
Probably a dumb question but how do I edit ,yaml, if I use core not hassio?
Ssh or samba or any other thing you can install next to ha core on your system.
It’s on a linux computer, so I can just literally edit that file?
Yes. Don’t forget you have to reload that component or in some cases restart HA.
@jason0x43 Thank you for the integration. I am following your steps using hubitat as my interface with Zwave and Zigbee.
Using locks (Schlage) I discovered that the more-info in a Card show all my passcodes. is there a way to hide them?
Hmmm…not that I’m aware of (which doesn’t mean there isn’t a way to hide them). The lock codes are part of the lock state, and HA (like Hubitat) doesn’t hide them.
I could potentially keep the codes out of the lock state, although having them available there seems like it may be pretty useful (I don’t have any locks, though).
I have the schlage locks (both zwave and zigbee versions) directly integrated with HA and they do not display the lock codes on any of the device pages. :man_shrugging:
It may be something specific to the Hubitat integration. Hubitat keeps the codes in its state and displays them in its own UI, and the Hubitat integration generally just maps Hubitat state to HA state.
Been stuck on this 15 mins.rpi4. It that normal?
What does stuck on this mean?
Help us understand where you’re hung up.
Sorry I thought I posted an image. Anyway finally worked. Thx
Sometimes you just need to hit it with a stick. (Home Automation software in general that is.)
:stuck_out_tongue_winking_eye:
May I ask why you would do this instead of just using a z stick with home assistant?
