Custom Component: Nikobus
New release on the github, next to the validation of the data received by Nikobus and ack of the command, I’ve added data to the button, if you have executed the discovery.
eg
Next on the discovery, if the user has not defined an impacted module address / group. it will be taken from the discovery.
So with this config, the user defined address and group will take priority
            "description": "BT_GF_Living_Sofa_Wall_Light_Up",
            "address": "004E2C",
            "impacted_module": [
                    "address": "0E6C",
                    "group": "1"
            "discovered_info": [
                    "type": "IR Button with 4 Operation Points",
                    "model": "05-348",
                    "address": "0D1C80",
                    "channels": 4,
                    "key": "1C"
            "discovered_link": [
                    "module_address": "0E6C",
                    "channel": "Channel 1",
                    "mode": "M01 (Dim on/off (2 buttons))",
                    "t1": "T2=Dimming time on; Dimming time off=1s",
                    "t2": "1 s"
In this other case, the discoved_link will be used as a failback as the user has not defined impacted_module
                    "address": "",
                    "group": ""
                    "model": "05-348",
                    "channels": 4,
                    "key": "1C"
                    "t2": "1 s"
I can only decode discovered_info and link for the module / button / … I own or for which I received user feedback. If some are not discovered in your specific case and usage, please revert and I will try to include it. While including something I do not own and can’t troubleshoot is always a kind of a challenge…
So back to the $0512 $0517 followed by the button address.
I no longer trust this should be ignored, but processed by HA.Reason being that if a $0517 or $0512 prefix the button address, Nikobus still process the button.
I now trust that we have only a clash between a refresh command answer, expecting a $0517 and $0512 as ACK and a button being pressed at the very same time.
Well; you know, I can only guess. I’m testing that new behaviour and will generate a new release if this goes better.
I’m new to HA and my first focus is on the integration with Nikobus. I have an old version of the modules (05-000-01 and 05-007-01). I knew that the compatibility with fdebrus great bridge wasn’t optimal in my case but it partially works. I can see pressed buttons and related events. This would be enough for me. I can handle the gaps.
My worries is more about the errors in the log file. Buttons are “discovered” and added as devices without any group or module address. As such it reports error due to the empty values. If I fill them in, it now reports about ACK timeout (I put 0000 as address as I don’t know the module address). Would it be possible to disable reading the module in such old Nikobus config ? Either by filtering on the module address value (empty or 0000) or on unsupported module model (e.g 05-000-01).
I’m ready to help in testing any of these modifications.
Thanks,
Not sure I get your story, let’s try to clarify
  • You have a very old Nikobus and you have no access to Nikobus software and can’t get the module address ?
  • How are you connected to Nikobus ? PC-Link ? other ?
So your question is about having only an interface to Nikobus that simulate button pressed and read events but does not do anything else ? You want to do so only because you do not know module address ?
If you are connected over PC Link, you can dump your Nikobus configuration with the following command:
Wait a couple of minutes, then check nikobus_module_discovered.json file in your HA config directory, it’s not used by the integration, only created to assist user.
May you have warning / missing data in the discovery, let me know, I will add your specific module to the discovery process. Share your nikobus_module_discovered.json file for that purpose.
Could you show me those errors ? This should be managed by the current version.
empty value should work and not generate error, Anything else like 0000 will not work, empty value should.
if not impacted_module_address or not impacted_group:
   _LOGGER.debug("Skipping module refresh due to missing address or group")
   continue
OK. Thanks for helping me.
Here are more details about my case:
  • I’m using a PC-Link but with an old version of the command/dimmer modules: 05-000-01 and 05-007-01
  • The inventory action is not generating any entries, not as module, not as button. I emptied these files and nothing was added.
  • However, when we press physicall buttons, these are discovered and added in the button.json file. Great! Keep in mind that the address=“” and group=“”.
  • From that time, the log indicates error due to the fact that group value is not an int.
  • What I did then is setting address=“0000” and group=“1”. Error was gone but another appeared about not contactable module 0000. Normal.
  • From your reactions I understood that address=“” should work. So I left address=“” but kept group=“1”. Much better. Still there is another error:
File “/config/custom_components/nikobus/button.py”, line 146, in async_press
value = await self._coordinator.nikobus_command.get_output_state(
module_address, module_group
File “/config/custom_components/nikobus/nkbcommand.py”, line 116, in get_output_state
command = make_pc_link_command(command_code, address)
File “/config/custom_components/nikobus/nkbprotocol.py”, line 52, in make_pc_link_command
addr_int = int(addr, 16)
ValueError: invalid literal for int() with base 16: ‘’
2025-04-21 18:05:16.916 ERROR (MainThread) [custom_components.nikobus.button] Failed to refresh module , group 1: invalid literal for int() with base 16: ‘’
I’m not sure what I should do. And indeed I don’t know how to get the list of module addresses, nor if this is valuable.
Looking for your advise. Thx.
As additional info:
  • The action is accepted but returns almost immediately with a green check. No error entries in the Log.
  • No new files created in the nikobus directory, except the default ones.
The error you are getting is related to HA trying to sync with Nikobus to get latest module status. Indeed this will fail if the module address are not defined. By design, HA and Nikobus shall be in sync and as such we have various refresh mechanism.
I can look at having an option so the user could define the integration with NO refresh.
But I’d like to clarify as well why you are getting no inventory, could you enable “debuglog” in the Nikobus integration page and then run the discovery 'it will return immediatly but process in the background", get me the debuglog over that period of execution with filter on “niko” to limit the log.
Look also for any error / warning from nikobus in the general log. Running a discovery wirh unsupported module shall get you a warning in the log like
Try with ‘feedback module’ checked. As you do not have a feedback module, this should result in no refresh mechanism to be triggered.
Still, this is a workaround, I would like to get your case sorted and enjoy the full experience :slight_smile: let’s work on the discovery failure.
Hi, I followed the steps. Here what I see in the log:
2025-04-21 21:11:18.691 INFO (MainThread) [custom_components.nikobus] Starting manual Nikobus discovery with module_address:
2025-04-21 21:11:18.693 DEBUG (MainThread) [custom_components.nikobus.coordinator] Starting device discovery from Nikobus
2025-04-21 21:11:18.693 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: #A
2025-04-21 21:11:18.693 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: #A
2025-04-21 21:11:18.695 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Dequeued command: #A
2025-04-21 21:11:18.695 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Processing command: #A with address: None
2025-04-21 21:11:18.696 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Sending command: #A
2025-04-21 21:11:18.781 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Received message: $0511$18E99400500F3FFF58B5CA
2025-04-21 21:11:18.781 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Adding unknown message to response queue: $0511$18E99400500F3FFF58B5CA
2025-04-21 21:11:28.782 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:11:38.783 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:11:48.785 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:11:58.787 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:12:08.788 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:12:18.790 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
ok, I see that your are getting the PC Link address, E994, checking why it’s not picked up by the integration.
You could press the “mode” button on the module till you hear a “beep”, this should also create the file in the config directory
As you module is currently unknown, it will generate the warning, if you could get me that data ?
I’ve fixed the discovery for your specific config, new release soon
Here what I get now also:
2025-04-21 21:29:15.114 INFO (MainThread) [custom_components.nikobus] Starting manual Nikobus discovery with module_address:
2025-04-21 21:29:15.115 DEBUG (MainThread) [custom_components.nikobus.coordinator] Starting device discovery from Nikobus
2025-04-21 21:29:15.115 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: #A
2025-04-21 21:29:15.115 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: #A
2025-04-21 21:29:15.117 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Dequeued command: #A
2025-04-21 21:29:15.118 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Processing command: #A with address: None
2025-04-21 21:29:15.118 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Sending command: #A
2025-04-21 21:29:15.218 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Received message: $18E99400500F3FFF58B5CA
2025-04-21 21:29:15.218 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Device address inventory: $18E99400500F3FFF58B5CA
2025-04-21 21:29:15.218 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A404570CFA
2025-04-21 21:29:15.219 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A404570CFA
2025-04-21 21:29:15.219 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A504643D5D
2025-04-21 21:29:15.219 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A504643D5D
2025-04-21 21:29:15.219 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A604316E2A
2025-04-21 21:29:15.219 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A604316E2A
2025-04-21 21:29:15.220 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A704025F42
2025-04-21 21:29:15.220 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A704025F42
2025-04-21 21:29:15.220 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A8041261E3
2025-04-21 21:29:15.220 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A8041261E3
2025-04-21 21:29:15.221 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A904215020
2025-04-21 21:29:15.221 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A904215020
2025-04-21 21:29:15.221 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AA047403DB
2025-04-21 21:29:15.221 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AA047403DB
2025-04-21 21:29:15.221 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AB0447329B
2025-04-21 21:29:15.222 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AB0447329B
2025-04-21 21:29:15.222 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AC04DEA547
2025-04-21 21:29:15.222 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AC04DEA547
2025-04-21 21:29:15.222 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AD04ED94AF
2025-04-21 21:29:15.222 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AD04ED94AF
2025-04-21 21:29:15.223 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AE04B8C7E0
2025-04-21 21:29:15.223 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AE04B8C7E0
2025-04-21 21:29:15.224 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AF048BF635
2025-04-21 21:29:15.224 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AF048BF635
2025-04-21 21:29:15.225 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B00498BBAB
2025-04-21 21:29:15.225 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B00498BBAB
2025-04-21 21:29:15.225 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B104AB8A7B
2025-04-21 21:29:15.225 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B104AB8A7B
2025-04-21 21:29:15.226 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B204FED9D6
2025-04-21 21:29:15.226 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B204FED9D6
2025-04-21 21:29:15.226 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B304CDE859
2025-04-21 21:29:15.226 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B304CDE859
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B404547F38
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B404547F38
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B504674E50
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B504674E50
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B604321D27
2025-04-21 21:29:15.227 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B604321D27
2025-04-21 21:29:15.228 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B704012C80
2025-04-21 21:29:15.228 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B704012C80
2025-04-21 21:29:15.228 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B804111245
2025-04-21 21:29:15.228 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B804111245
2025-04-21 21:29:15.229 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B904222386
2025-04-21 21:29:15.229 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B904222386
2025-04-21 21:29:15.229 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BA0477707D
2025-04-21 21:29:15.230 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BA0477707D
2025-04-21 21:29:15.231 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BB0444413D
2025-04-21 21:29:15.231 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BB0444413D
2025-04-21 21:29:15.231 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BC04DDD610
2025-04-21 21:29:15.231 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BC04DDD610
2025-04-21 21:29:15.232 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BD04EEE755
2025-04-21 21:29:15.232 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BD04EEE755
2025-04-21 21:29:15.232 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BE04BBB490
2025-04-21 21:29:15.232 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BE04BBB490
2025-04-21 21:29:15.232 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BF04888503
2025-04-21 21:29:15.233 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BF04888503
2025-04-21 21:29:15.233 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C00490E2A0
2025-04-21 21:29:15.233 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C00490E2A0
2025-04-21 21:29:15.233 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C104A3D312
2025-04-21 21:29:15.233 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C104A3D312
2025-04-21 21:29:15.234 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C204F68008
2025-04-21 21:29:15.234 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C204F68008
2025-04-21 21:29:15.234 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C304C5B1DB
2025-04-21 21:29:15.234 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C304C5B1DB
2025-04-21 21:29:15.234 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C4045C2636
2025-04-21 21:29:15.235 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C4045C2636
2025-04-21 21:29:15.235 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C5046F1794
2025-04-21 21:29:15.235 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C5046F1794
2025-04-21 21:29:15.236 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C6043A44E0
2025-04-21 21:29:15.236 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C6043A44E0
2025-04-21 21:29:15.237 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C7040975B6
2025-04-21 21:29:15.237 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C7040975B6
2025-04-21 21:29:15.237 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C804194B17
2025-04-21 21:29:15.237 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C804194B17
2025-04-21 21:29:15.238 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C9042A7AEA
2025-04-21 21:29:15.238 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C9042A7AEA
2025-04-21 21:29:15.238 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CA047F29A6
2025-04-21 21:29:15.238 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CA047F29A6
2025-04-21 21:29:15.238 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CB044C1887
2025-04-21 21:29:15.239 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CB044C1887
2025-04-21 21:29:15.239 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CC04D58FD2
2025-04-21 21:29:15.239 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CC04D58FD2
2025-04-21 21:29:15.239 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CD04E6BE60
2025-04-21 21:29:15.239 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CD04E6BE60
2025-04-21 21:29:15.240 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CE04B3EDA6
2025-04-21 21:29:15.240 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CE04B3EDA6
2025-04-21 21:29:15.240 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CF0480DC98
2025-04-21 21:29:15.240 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CF0480DC98
2025-04-21 21:29:15.241 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D004939176
2025-04-21 21:29:15.241 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D004939176
2025-04-21 21:29:15.241 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D104A0A069
2025-04-21 21:29:15.241 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D104A0A069
2025-04-21 21:29:15.242 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D204F5F387
2025-04-21 21:29:15.242 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D204F5F387
2025-04-21 21:29:15.242 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D304C6C212
2025-04-21 21:29:15.242 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D304C6C212
2025-04-21 21:29:15.243 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D4045F5575
2025-04-21 21:29:15.243 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D4045F5575
2025-04-21 21:29:15.243 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D5046C64D7
2025-04-21 21:29:15.243 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D5046C64D7
2025-04-21 21:29:15.243 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D604393757
2025-04-21 21:29:15.244 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D604393757
2025-04-21 21:29:15.244 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D7040A0601
2025-04-21 21:29:15.244 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D7040A0601
2025-04-21 21:29:15.244 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D8041A3814
2025-04-21 21:29:15.244 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D8041A3814
2025-04-21 21:29:15.245 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D904290942
2025-04-21 21:29:15.245 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D904290942
2025-04-21 21:29:15.245 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DA047C5AFA
2025-04-21 21:29:15.245 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DA047C5AFA
2025-04-21 21:29:15.245 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DB044F6B70
2025-04-21 21:29:15.246 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DB044F6B70
2025-04-21 21:29:15.246 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DC04D6FC39
2025-04-21 21:29:15.246 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DC04D6FC39
2025-04-21 21:29:15.247 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DD04E5CD02
2025-04-21 21:29:15.247 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DD04E5CD02
2025-04-21 21:29:15.248 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DE04B09EDB
2025-04-21 21:29:15.248 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DE04B09EDB
2025-04-21 21:29:15.248 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DF0483AF87
2025-04-21 21:29:15.249 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DF0483AF87
2025-04-21 21:29:15.249 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E004960481
2025-04-21 21:29:15.249 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E004960481
2025-04-21 21:29:15.249 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E104A5356A
2025-04-21 21:29:15.249 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E104A5356A
2025-04-21 21:29:15.250 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E204F066DD
2025-04-21 21:29:15.250 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E204F066DD
2025-04-21 21:29:15.250 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E304C357A3
2025-04-21 21:29:15.250 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E304C357A3
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E4045AC06C
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E4045AC06C
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E50469F1D1
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E50469F1D1
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E6043CA208
2025-04-21 21:29:15.251 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E6043CA208
2025-04-21 21:29:15.252 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E7040F935E
2025-04-21 21:29:15.252 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E7040F935E
2025-04-21 21:29:15.253 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E8041FAD0B
2025-04-21 21:29:15.254 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E8041FAD0B
2025-04-21 21:29:15.254 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E9042C9C39
2025-04-21 21:29:15.255 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E9042C9C39
2025-04-21 21:29:15.255 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EA0479CFBC
2025-04-21 21:29:15.255 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EA0479CFBC
2025-04-21 21:29:15.255 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EB044AFE29
2025-04-21 21:29:15.255 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EB044AFE29
2025-04-21 21:29:15.256 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EC04D369B3
2025-04-21 21:29:15.256 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EC04D369B3
2025-04-21 21:29:15.256 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994ED04E05807
2025-04-21 21:29:15.256 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994ED04E05807
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EE04B50B87
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EE04B50B87
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EF04863A2F
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EF04863A2F
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F004957727
2025-04-21 21:29:15.257 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F004957727
2025-04-21 21:29:15.258 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F104A646CC
2025-04-21 21:29:15.258 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F104A646CC
2025-04-21 21:29:15.258 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F204F3157B
2025-04-21 21:29:15.259 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F204F3157B
2025-04-21 21:29:15.260 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F304C02405
2025-04-21 21:29:15.260 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F304C02405
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F40459B3B4
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F40459B3B4
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F5046A824F
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F5046A824F
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F6043FD196
2025-04-21 21:29:15.261 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F6043FD196
2025-04-21 21:29:15.262 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F7040CE06D
2025-04-21 21:29:15.262 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F7040CE06D
2025-04-21 21:29:15.262 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F8041CDE3E
2025-04-21 21:29:15.262 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F8041CDE3E
2025-04-21 21:29:15.263 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F9042FEF6E
2025-04-21 21:29:15.263 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F9042FEF6E
2025-04-21 21:29:15.263 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FA047ABC00
2025-04-21 21:29:15.263 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FA047ABC00
2025-04-21 21:29:15.263 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FB04498D1C
2025-04-21 21:29:15.264 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FB04498D1C
2025-04-21 21:29:15.264 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FC04D01A0A
2025-04-21 21:29:15.264 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FC04D01A0A
2025-04-21 21:29:15.265 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FD04E32B15
2025-04-21 21:29:15.265 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FD04E32B15
2025-04-21 21:29:15.266 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FE04B67895
2025-04-21 21:29:15.266 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FE04B67895
2025-04-21 21:29:15.823 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Dequeued command: $1410E994A404570CFA
2025-04-21 21:29:15.823 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Processing command: $1410E994A404570CFA with address: None
2025-04-21 21:29:15.823 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Sending command: $1410E994A404570CFA
2025-04-21 21:29:15.959 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Received message: $0510$2EE994FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF006A42
2025-04-21 21:29:15.960 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Device inventory: $0510$2EE994FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF006A42
2025-04-21 21:29:25.962 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:29:35.963 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:29:45.965 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:29:55.966 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
Still no new file in nikobus or config directory.
Thanks for your effort.
Could you double check the module you are connected to is a PCLink ? not a PCLogic ?
As we query the first register to dump its memory, it’s all FFFFF… which means empty. I do not expect this from a PCLink but from a PCLogic. What is the reference of the module you are connected to ?
It is a PC-Link 05-200. From the same year as the command/dimmer 1999-2000.
I have also a 05-207 available but not connected currently. Is it worth connecting this in place of PC-Link ?
We have more chances with the “mode” button from the module, if you push them and wait for the beep, do you get a warning in HA log ?
Only the PC Link holds the inventory of the Nikobus installation, weird not in your case. Pushing yellow “mode” button is our only next step then.
Here what I get by sending ID (there is no mode button):
2025-04-21 21:50:30.390 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:50:40.391 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:50:50.392 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:50:53.447 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Received message: $18E99400500F3FFF58B5CA
2025-04-21 21:50:53.448 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Device address inventory: $18E99400500F3FFF58B5CA
2025-04-21 21:50:53.448 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A404570CFA
2025-04-21 21:50:53.449 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A404570CFA
2025-04-21 21:50:53.449 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A504643D5D
2025-04-21 21:50:53.449 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A504643D5D
2025-04-21 21:50:53.449 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A604316E2A
2025-04-21 21:50:53.450 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A604316E2A
2025-04-21 21:50:53.450 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A704025F42
2025-04-21 21:50:53.450 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A704025F42
2025-04-21 21:50:53.450 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A8041261E3
2025-04-21 21:50:53.451 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A8041261E3
2025-04-21 21:50:53.451 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994A904215020
2025-04-21 21:50:53.451 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994A904215020
2025-04-21 21:50:53.451 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AA047403DB
2025-04-21 21:50:53.451 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AA047403DB
2025-04-21 21:50:53.452 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AB0447329B
2025-04-21 21:50:53.452 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AB0447329B
2025-04-21 21:50:53.452 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AC04DEA547
2025-04-21 21:50:53.452 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AC04DEA547
2025-04-21 21:50:53.453 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AD04ED94AF
2025-04-21 21:50:53.453 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AD04ED94AF
2025-04-21 21:50:53.454 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AE04B8C7E0
2025-04-21 21:50:53.454 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AE04B8C7E0
2025-04-21 21:50:53.455 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994AF048BF635
2025-04-21 21:50:53.455 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994AF048BF635
2025-04-21 21:50:53.456 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B00498BBAB
2025-04-21 21:50:53.456 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B00498BBAB
2025-04-21 21:50:53.456 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B104AB8A7B
2025-04-21 21:50:53.456 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B104AB8A7B
2025-04-21 21:50:53.456 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B204FED9D6
2025-04-21 21:50:53.457 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B204FED9D6
2025-04-21 21:50:53.457 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B304CDE859
2025-04-21 21:50:53.457 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B304CDE859
2025-04-21 21:50:53.457 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B404547F38
2025-04-21 21:50:53.457 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B404547F38
2025-04-21 21:50:53.458 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B504674E50
2025-04-21 21:50:53.458 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B504674E50
2025-04-21 21:50:53.458 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B604321D27
2025-04-21 21:50:53.458 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B604321D27
2025-04-21 21:50:53.459 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B704012C80
2025-04-21 21:50:53.460 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B704012C80
2025-04-21 21:50:53.460 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B804111245
2025-04-21 21:50:53.461 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B804111245
2025-04-21 21:50:53.461 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994B904222386
2025-04-21 21:50:53.461 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994B904222386
2025-04-21 21:50:53.462 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BA0477707D
2025-04-21 21:50:53.462 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BA0477707D
2025-04-21 21:50:53.462 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BB0444413D
2025-04-21 21:50:53.462 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BB0444413D
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BC04DDD610
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BC04DDD610
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BD04EEE755
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BD04EEE755
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BE04BBB490
2025-04-21 21:50:53.463 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BE04BBB490
2025-04-21 21:50:53.464 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994BF04888503
2025-04-21 21:50:53.464 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994BF04888503
2025-04-21 21:50:53.464 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C00490E2A0
2025-04-21 21:50:53.464 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C00490E2A0
2025-04-21 21:50:53.465 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C104A3D312
2025-04-21 21:50:53.466 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C104A3D312
2025-04-21 21:50:53.466 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C204F68008
2025-04-21 21:50:53.467 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C204F68008
2025-04-21 21:50:53.467 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C304C5B1DB
2025-04-21 21:50:53.467 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C304C5B1DB
2025-04-21 21:50:53.467 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C4045C2636
2025-04-21 21:50:53.468 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C4045C2636
2025-04-21 21:50:53.468 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C5046F1794
2025-04-21 21:50:53.468 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C5046F1794
2025-04-21 21:50:53.468 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C6043A44E0
2025-04-21 21:50:53.468 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C6043A44E0
2025-04-21 21:50:53.469 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C7040975B6
2025-04-21 21:50:53.469 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C7040975B6
2025-04-21 21:50:53.469 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C804194B17
2025-04-21 21:50:53.469 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C804194B17
2025-04-21 21:50:53.470 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994C9042A7AEA
2025-04-21 21:50:53.470 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994C9042A7AEA
2025-04-21 21:50:53.470 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CA047F29A6
2025-04-21 21:50:53.470 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CA047F29A6
2025-04-21 21:50:53.471 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CB044C1887
2025-04-21 21:50:53.472 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CB044C1887
2025-04-21 21:50:53.472 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CC04D58FD2
2025-04-21 21:50:53.473 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CC04D58FD2
2025-04-21 21:50:53.473 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CD04E6BE60
2025-04-21 21:50:53.473 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CD04E6BE60
2025-04-21 21:50:53.474 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CE04B3EDA6
2025-04-21 21:50:53.474 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CE04B3EDA6
2025-04-21 21:50:53.474 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994CF0480DC98
2025-04-21 21:50:53.474 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994CF0480DC98
2025-04-21 21:50:53.475 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D004939176
2025-04-21 21:50:53.475 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D004939176
2025-04-21 21:50:53.475 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D104A0A069
2025-04-21 21:50:53.475 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D104A0A069
2025-04-21 21:50:53.476 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D204F5F387
2025-04-21 21:50:53.476 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D204F5F387
2025-04-21 21:50:53.476 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D304C6C212
2025-04-21 21:50:53.476 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D304C6C212
2025-04-21 21:50:53.476 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D4045F5575
2025-04-21 21:50:53.477 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D4045F5575
2025-04-21 21:50:53.478 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D5046C64D7
2025-04-21 21:50:53.478 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D5046C64D7
2025-04-21 21:50:53.479 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D604393757
2025-04-21 21:50:53.479 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D604393757
2025-04-21 21:50:53.479 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D7040A0601
2025-04-21 21:50:53.479 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D7040A0601
2025-04-21 21:50:53.480 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D8041A3814
2025-04-21 21:50:53.480 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D8041A3814
2025-04-21 21:50:53.480 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994D904290942
2025-04-21 21:50:53.480 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994D904290942
2025-04-21 21:50:53.481 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DA047C5AFA
2025-04-21 21:50:53.481 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DA047C5AFA
2025-04-21 21:50:53.481 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DB044F6B70
2025-04-21 21:50:53.481 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DB044F6B70
2025-04-21 21:50:53.482 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DC04D6FC39
2025-04-21 21:50:53.482 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DC04D6FC39
2025-04-21 21:50:53.482 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DD04E5CD02
2025-04-21 21:50:53.482 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DD04E5CD02
2025-04-21 21:50:53.482 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DE04B09EDB
2025-04-21 21:50:53.483 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DE04B09EDB
2025-04-21 21:50:53.484 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994DF0483AF87
2025-04-21 21:50:53.484 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994DF0483AF87
2025-04-21 21:50:53.485 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E004960481
2025-04-21 21:50:53.485 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E004960481
2025-04-21 21:50:53.485 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E104A5356A
2025-04-21 21:50:53.485 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E104A5356A
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E204F066DD
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E204F066DD
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E304C357A3
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E304C357A3
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E4045AC06C
2025-04-21 21:50:53.486 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E4045AC06C
2025-04-21 21:50:53.487 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E50469F1D1
2025-04-21 21:50:53.487 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E50469F1D1
2025-04-21 21:50:53.487 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E6043CA208
2025-04-21 21:50:53.487 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E6043CA208
2025-04-21 21:50:53.488 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E7040F935E
2025-04-21 21:50:53.488 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E7040F935E
2025-04-21 21:50:53.488 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E8041FAD0B
2025-04-21 21:50:53.488 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E8041FAD0B
2025-04-21 21:50:53.488 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994E9042C9C39
2025-04-21 21:50:53.490 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994E9042C9C39
2025-04-21 21:50:53.490 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EA0479CFBC
2025-04-21 21:50:53.491 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EA0479CFBC
2025-04-21 21:50:53.491 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EB044AFE29
2025-04-21 21:50:53.491 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EB044AFE29
2025-04-21 21:50:53.491 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EC04D369B3
2025-04-21 21:50:53.491 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EC04D369B3
2025-04-21 21:50:53.492 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994ED04E05807
2025-04-21 21:50:53.492 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994ED04E05807
2025-04-21 21:50:53.492 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EE04B50B87
2025-04-21 21:50:53.492 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EE04B50B87
2025-04-21 21:50:53.493 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994EF04863A2F
2025-04-21 21:50:53.493 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994EF04863A2F
2025-04-21 21:50:53.493 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F004957727
2025-04-21 21:50:53.493 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F004957727
2025-04-21 21:50:53.493 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F104A646CC
2025-04-21 21:50:53.494 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F104A646CC
2025-04-21 21:50:53.494 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F204F3157B
2025-04-21 21:50:53.494 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F204F3157B
2025-04-21 21:50:53.494 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F304C02405
2025-04-21 21:50:53.494 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F304C02405
2025-04-21 21:50:53.496 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F40459B3B4
2025-04-21 21:50:53.496 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F40459B3B4
2025-04-21 21:50:53.497 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F5046A824F
2025-04-21 21:50:53.497 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F5046A824F
2025-04-21 21:50:53.497 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F6043FD196
2025-04-21 21:50:53.497 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F6043FD196
2025-04-21 21:50:53.498 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F7040CE06D
2025-04-21 21:50:53.498 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F7040CE06D
2025-04-21 21:50:53.498 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F8041CDE3E
2025-04-21 21:50:53.498 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F8041CDE3E
2025-04-21 21:50:53.498 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994F9042FEF6E
2025-04-21 21:50:53.499 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994F9042FEF6E
2025-04-21 21:50:53.499 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FA047ABC00
2025-04-21 21:50:53.499 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FA047ABC00
2025-04-21 21:50:53.499 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FB04498D1C
2025-04-21 21:50:53.499 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FB04498D1C
2025-04-21 21:50:53.500 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FC04D01A0A
2025-04-21 21:50:53.500 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FC04D01A0A
2025-04-21 21:50:53.500 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FD04E32B15
2025-04-21 21:50:53.501 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FD04E32B15
2025-04-21 21:50:53.502 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Queueing command: $1410E994FE04B67895
2025-04-21 21:50:53.502 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Command queued: $1410E994FE04B67895
2025-04-21 21:50:53.502 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Dequeued command: $1410E994A404570CFA
2025-04-21 21:50:53.503 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Processing command: $1410E994A404570CFA with address: None
2025-04-21 21:50:53.503 DEBUG (MainThread) [custom_components.nikobus.nkbcommand] Sending command: $1410E994A404570CFA
2025-04-21 21:50:53.638 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Received message: $0510$2EE994FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF006A42
2025-04-21 21:50:53.639 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Device inventory: $0510$2EE994FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF006A42
2025-04-21 21:51:03.640 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
2025-04-21 21:51:13.641 DEBUG (MainThread) [custom_components.nikobus.nkblistener] Read operation timed out. Waiting for next data…
I mean pushing “mode” button on those modules, and any other your might have
This is no generating any new line. It seems that the mode button is not reacting with -01 as for -02. No beep even after 10 sec. I tried both types of modules.
Nothing in the HA log . info / warning / error ? from Nikobus integration ?
