I’ve downloaded a custom component from GitHub and put the files in /custom_components/omnik_inverter/ as statet in the description.
After restarting HAS i can see the following warning in the log:
WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration omnik_inverter which has not been tested by Home Assistant. This component might cause stability problems, be sure to disablestrong text it if you experience issues with Home Assistant
The componets seems to be loaded by HAS, but I cannot add and configure it as a integration?
a couple ot these:
2022-05-25 16:19:23 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140397847642016] Received invalid command: energy/info
