[Custom Component] OpenWA WhatsApp - Self-Hosted WhatsApp Notifications
Hi everyone,
I've been looking for a way to get WhatsApp notifications without relying on expensive cloud bridges or 3rd party services that have limited free
tiers. I ended up using the OpenWA API and decided to write a custom integration for it so we can trigger messages directly from our automations.
It's completely self-hosted, meaning your messages go through your own server.
Why I built this:
I wanted a reliable way to get critical alerts (like water leaks or security/door alerts) on WhatsApp without the lag or cost of typical SMS
gateways.
What it does:
  • Sends text messages to any contact or group.
  • Fully configured via the HA UI.
  • Supports templates, so you can send dynamic data (e.g., "The living room temperature is {{ states('sensor.temp') }}°C").
I've put together a full guide and the code on GitHub, including a 1-line Docker command to get the API server running if you're new to OpenWA.
Repo: openwa-whatsapp
I'm still polishing it and would love to know if anyone else has a specific use case they'd like to see supported!
Is it possible to do this without the docker image? Or run the docker image inside HA?
you can try this
I’m working on an addon, but haven’t got a chance to test it. In my setup, I set up the docker container on my unraid and then linked my phone with the QR code. After that I started working on the hacs component.
I did finish the work in creating the add-on GitHub - nomi25home/homeassistant-openwa-addon · GitHub
