[Custom Component] TP-Link Router Integration (supports also Mercusys router)
v2.4.0 Released
Changelog
Added support for Archer VX1800v v1.0
v2.5.0 Released
Changelog
  • Added Archer VR1200v v1 support
Break change
  • sensor IPv4 Connection Type is no longer exist, now it called Connection Type
  • For EX routers if you used username different from admin the integration connection to router will fail. If it does - you need to change username to yours in integration configuration
Could you test the latest version of GitHub - AlexandrErohin/TP-Link-Archer-C6U: Python package for API access and management for TP-Link Routers. See supported routers list ?
For those who has an unsupported router like C6V4, c60, c80…
Could you try the latest version of the client GitHub - AlexandrErohin/TP-Link-Archer-C6U: Python package for API access and management for TP-Link Routers. See supported routers list
You need to run this Python code
from tplinkrouterc6u import TplinkRouterProvider
from logging import Logger
router = TplinkRouterProvider.get_client('http://192.168.0.1', 'password')
router.authorize()
router.get_firmware()
router.get_status()
And let me know if there any errors or not
v2.6.0 Released
Changelog
  • Added Archer C80 1.0 and 2.20 support
  • Added XC220-G3v v2.30 to supported router list
  • Added Deco XE75PRO (v3.0) to supported router list
Could you try the latest version please?
The XE75Pro does not appear to be fully supported, as the switches to enable / disable wifi does not work, and is still having issues related to this issues from 2024: Can't turn on/off Guest Wifi on Deco · Issue #73 · AlexandrErohin/home-assistant-tplink-router · GitHub
Device Info:
XE75 PRO
Firmware: 1.2.11 Build 20240724 Rel. 38913
Hardware: 3.0
On v2.6.0
The issue is related to the fact that the switches are split by frequency, but the Deco app now groups 2.4 and 5 GHz channels into the same switch. This causes an error: tplinkrouterc6u.common.exception.ClientError: TplinkRouter - TPLinkDecoClient - An unknown response - Expecting value: line 1 column 1 (char 0); Request admin/wireless?form=wlan
When using the switches. I attempted to find the correct API call using the inspecting the commands sent by the web interface, but there are no longer the switches there.
@ConnorHayward Unfortunately, I don’t have the Deco device now - so I cannot debug and research this bug :frowning:
v2.7.0 Released
Changelog
  • Added support Archer A8 1.0
  • Added support Archer C6 4.0
  • Added support Archer C24 2.0
  • Added support Archer C60 v2.0
  • Added support Mercusys MR47BE v1.0
  • Added support Mercusys H60XR 1.0
  • Fixed SSL Verification
  • Fixed KeyError: ‘33|1,9,0’
v2.7.1 Released
Changelog
  • Added timeout retry for Deco devices
  • Added TL-WA1201 3.0 to supported list
  • Added C24 1.0 and 2.0 to supported list
  • Added Mercusys routers MR50G 1.0 to supported list
Hi @AlexandrErohin
So I setup this integration with an Archer C6 v4. All went ok.
The main issue I have is that devicetracker always reports my devices (phones) as home. Even if on the WebGui of the router the devices appear as offline (which is correct cause i’m not even connected to the Wifi). Any idea of what’s wrong?
V
@carocho Should be fixed now
v2.7.1 Released
Changelog
Trying to install this integration for a AXE5400… this is what I get… and YES the ip address is correct…
HTTPSConnectionPool(host=‘192.168.1.1’, port=443): Max retries exceeded with url: /webpages/index.html (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1028)’)))
Can anyone tell me why I can’t get this integration to work?
Thank you!
Try to unset Verify ssl in the configuration
Thank you… this time when I went to install integration it asked if I wanted to verify and I said no and it worked…
@cowboysdude What is your router hardware version?
v2.8.0 Released
Changelog
  • Added support for TL-WDR3600
  • Fixed support for Archer BE550 v1.0
  • Added Archer A6 V2.0 to the supported list
Sorry I didn’t see this sooner… I did get it working with by unsetting verify ssl. My hardware version is: Archer AXE5400 v1.0
