I’ve made two custom components a while ago and they have worked fine for a while. But since updating to 0.68 (I don’t remember from which version I updated to 0.68) they just fail to work. They are in a custom_components directory and both in another directory for their platform (as shown in the picture).
I’ve got Hass.io set up on my Raspberry pi 3 and both the components use the GPIO pins of the Raspberry. There are no logs or errors, from the HA log everything seems to work fine but the GPIO’s don’t react anymore.
Please find the two components in python attached.
Any suggestions?
The Kallox component for controlling my curtains.
import logging
from time import sleep
import voluptuous as vol
from homeassistant.components.cover import CoverDevice, PLATFORM_SCHEMA
from homeassistant.const import CONF_NAME
import homeassistant.components.rpi_gpio as rpi_gpio
import homeassistant.helpers.config_validation as cv
_LOGGER = logging.getLogger(__name__)
CONF_COVERS = 'covers'
CONF_OPEN_PIN = 'open_pin'
CONF_CLOSE_PIN = 'close_pin'
CONF_STOP_PIN = 'stop_pin'
CONF_RELAY_TIME = 'relay_time'
CONF_ROLL_TIME = 'roll_time'
DEFAULT_RELAY_TIME = .2
DEPENDENCIES = ['rpi_gpio']
_COVERS_SCHEMA = vol.All(
cv.ensure_list,
vol.Schema({
CONF_NAME: cv.string,
CONF_OPEN_PIN: cv.positive_int,
CONF_CLOSE_PIN: cv.positive_int,
CONF_STOP_PIN: cv.positive_int,
CONF_ROLL_TIME: cv.positive_int,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_COVERS): _COVERS_SCHEMA,
vol.Optional(CONF_RELAY_TIME, default=DEFAULT_RELAY_TIME): cv.positive_int,
# pylint: disable=unused-argument
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Set up the RPi cover platform."""
relay_time = config.get(CONF_RELAY_TIME)
covers = []
covers_conf = config.get(CONF_COVERS)
for cover in covers_conf:
covers.append(kallox(
cover[CONF_NAME], cover[CONF_OPEN_PIN], cover[CONF_CLOSE_PIN],
cover[CONF_STOP_PIN], cover[CONF_ROLL_TIME], relay_time))
add_devices(covers)
class kallox(CoverDevice):
"""Representation of a Raspberry GPIO cover."""
def __init__(self, name, open_pin, close_pin, stop_pin, roll_time,
relay_time):
"""Initialize the cover.
False = open or stopped
True = Opened """
self._name = name
self._state = False
self._open_pin = open_pin
self._close_pin = close_pin
self._stop_pin = stop_pin
self._roll_time = roll_time
self._relay_time = relay_time
rpi_gpio.setup_output(self._open_pin)
rpi_gpio.setup_output(self._close_pin)
rpi_gpio.setup_output(self._stop_pin)
rpi_gpio.write_output(self._open_pin, False)
rpi_gpio.write_output(self._close_pin, False)
rpi_gpio.write_output(self._stop_pin, False)
@property
def unique_id(self):
"""Return the ID of this cover."""
return '{}.{}'.format(self.__class__, self._name)
@property
def name(self):
"""Return the name of the cover if any."""
return self._name
def update(self):
"""Update the state of the cover."""
self._state = self._state
@property
def is_closed(self):
"""Return true if cover is closed."""
return self._state
def close_cover(self):
"""Close the cover."""
if self._state == True:
return
rpi_gpio.write_output(self._close_pin, True)
sleep(self._relay_time)
sleep(self._roll_time)
rpi_gpio.write_output(self._stop_pin, True)
self._state = True
def open_cover(self):
"""Open the cover."""
rpi_gpio.write_output(self._open_pin, True)
self._state = False
def stop_cover(self):
""" stop the cover """
self._state = False
The relay component for giving short pulses to a 12V relay.
import logging
from homeassistant.components.switch import (SwitchDevice, PLATFORM_SCHEMA)
from homeassistant.const import DEVICE_DEFAULT_NAME
from homeassistant.helpers.entity import ToggleEntity
CONF_PULL_MODE = 'pull_mode'
CONF_PORTS = 'ports'
CONF_INVERT_LOGIC = 'invert_logic'
DEFAULT_RELAY_TIME = 0.2
DEFAULT_INVERT_LOGIC = False
_SWITCHES_SCHEMA = vol.Schema({
cv.positive_int: cv.string,
vol.Required(CONF_PORTS): _SWITCHES_SCHEMA,
vol.Optional(CONF_INVERT_LOGIC, default=DEFAULT_INVERT_LOGIC): cv.boolean,
"""Setup the Raspberry PI GPIO devices."""
invert_logic = config.get(CONF_INVERT_LOGIC)
switches = []
ports = config.get(CONF_PORTS)
for port, name in ports.items():
switches.append(RPiGPIO_relay(name, port, invert_logic, relay_time))
add_devices(switches)
class RPiGPIO_relay(ToggleEntity):
"""Representation of a Raspberry Pi GPIO."""
def __init__(self, name, port, invert_logic, relay_time):
"""Initialize the pin."""
self._name = name or DEVICE_DEFAULT_NAME
self._port = port
self._invert_logic = invert_logic
self._state = False
rpi_gpio.setup_output(self._port)
rpi_gpio.write_output(self._port, 1 if self._invert_logic else 0)
@property
def name(self):
"""Return the name of the switch."""
return self._name
@property
def should_poll(self):
"""No polling needed."""
return False
@property
def is_on(self):
"""Return true if device is on."""
return self._state
def turn_on(self):
"""Turn the device on."""
return
rpi_gpio.write_output(self._port, 0 if self._invert_logic else 1)
self._state = True
self.schedule_update_ha_state()
def turn_off(self):
"""Turn the device off."""
if self._state == False:
return
self._state = False
