I’m new to ESPHome and quite impressed what it can do. Many thanks at this point to all contributors.
After doing my first steps I want to integrate one display which I have here into ESPHome: W082XLG
I tried to create a clone of the existing LCD integration and then add it via a custom include. The basis config in the yaml was as well the LCD example. Unfortunately I cannot use that module. It is not recognized as Plattform custom nore the name I gave it.
Is this mechanism not possible for displays?
Any idea? Did anyone already create custom displays?
So I thought I take the existing LCD code as a reference:
Anyway, what I did is copying the folder from the link before in my config folder, renamed it accordingly: esphome-configs/lcd_W082-XLG/ → display.py → init.py → w082xlg_display.cpp → w082xlg_display.h
Then I integrated the entire folder:
esphome:
includes:
- lcd_W082-XLG
The is no difference when I directly link the .h file.
Then I tried to add it as a display:
Partly I was able to create a custom display but I didn’t get it working with the internal SPI. The original example code was using a custom SPI implementation that did the job.
BUT: first I was doing it on an esp8266 where it was working like a charm, on an ESP32 it was constantly failing and only showing rubbish. This is why I replaced it
Unfortunately I was not able to recover the code as I gave up this display. It was not running stable due to the emulated SPI.
But as far as I remember I was using the full path to get it properly building …
