Custom ESPHome Firmware for Sonoff PowR2 – Looking for Testers & Feedback
EDIT: I’ve updated this post to share a new revision (Rev 2.0) with improved load detection, burst logic, and overall measurement stability.
Hi everyone,
I’ve been working on a custom ESPHome firmware for the Sonoff PowR2, and I’d like to share it with the community in case someone wants to test it, review the logic, or suggest improvements.
The main goal of this project is to achieve stable and accurate measurements, reliable energy tracking, and clean integration with Home Assistant, while keeping the device responsive and predictable during relay ON/OFF transitions.
This firmware is based on ESPHome 2025.12.7 and uses the internal CSE7766 sensor.
Main Features
Measurement & Data Processing
  • Reads voltage, current, and power directly from the CSE7766 sensor
  • Voltage is always sampled and averaged, even when the relay is OFF
  • Current and power are sampled only when the relay is ON
  • Power is primarily taken from the CSE7766 power register
  • A fallback estimation of current (I ≈ P / V) is used only when measured current is extremely low, but power is non-zero.
  • Sensor samples are accumulated and averaged over a configurable time window
  • Values are published to Home Assistant only when they change beyond a small threshold
Load Detection & Burst Mode
  • Measurements start only after a real electrical load is detected
  • A load is detected when:
    • Relay is ON
    • Power exceeds ~1.8 W
  • When a load is detected, the firmware enters Burst Mode:
    • For ~3 seconds, raw sensor values are published immediately, this provides instant feedback even with long scan intervals
  • After burst mode: measurements switches back to averaged values only
  • Measurement is halted when relay is turned OFF or UART watchdog detects stalled CSE7766 communication.This prevents publishing phantom or frozen measurements to Home Assistant
Energy Management
  • Energy is calculated by integrating instantaneous raw power every second
  • Energy accumulation happens in RAM
  • Two counters are exposed:
    • Daily Energy (kWh)
    • Total Energy (kWh)
  • Optional flash synchronization every 10 minutes to reduce flash wear
  • Energy values can be restored after power loss if saved in flash
  • Daily energy is automatically reset at local midnight, SNTP-based time configurable (default: Europe/Rome)
Overcurrent Protection (OCP)
  • Optional and fully configurable
  • User-defined maximum current threshold
  • When enabled:
    • Relay is turned OFF if the threshold is exceeded
    • A short OCP Alarm binary sensor is triggered for 1 second
Configuration Options (All Stored in Flash)
  • Boot Mode
    • Always OFF
    • Always ON
    • Restore Previous State
  • Scan Time (1–60 s)
    • Averaging and publishing interval
  • Voltage Offset / Current Offset
    • Calibration offsets applied to raw measurements
  • Status LED
    • Always ON
    • OFF after WiFi connection
  • Overcurrent Protection
    • Enable / Disable
    • Max current threshold
  • Save Energy to Flash
    • Enable / Disable periodic energy persistence
All settings are restored automatically after reboot or power loss.
Entities Exposed to Home Assistant
Sensors
  • Voltage (V)
  • Current (A)
  • Power (W)
  • Energy Today (kWh)
  • WiFi Signal (dB)
  • Uptime
Binary Sensors
  • OCP Alarm
Switches
  • Relay
  • Overcurrent Protection Enable
  • Restart Device
Buttons
  • Reset Energy Counters
here is the code Rev 2.0:
# ESPHome Firmware for Sonoff PowR2
# Rev 2.0 2026/01/20
# Ivo Colleoni
# ESPHOME 2025.12.7
# This firmware reads voltage, current, and power from the internal CSE7766 sensor
# and performs advanced filtering, averaging, and energy calculation.
# The following values are sent to Home Assistant:
#   - Voltage (averaged)
#   - Current (averaged)
#   - Instantaneous Power (averaged)
#   - Daily Energy (kWh)
#   - Total Energy (kWh)
#   - OCP Alarm (ON for 1 second when overcurrent protection trips)
#   - WiFi Signal
#   - Uptime
# The relay can be controlled from Home Assistant and the physical button.
# CONFIGURATION ENTITIES
#   - Boot Mode: selects the relay state at startup (ON / OFF / PREVIOUS STATE)
#   - Scan Time: defines the averaging and publishing interval (1–60 seconds)
#   - Status LED: sets the LED state after connection (ON / OFF)
#   - Voltage and Current Offsets: adjustable
#   - Max Current Threshold: maximum allowed current for OCP (0–16 A)
#   - Overcurrent Protection (OCP): when enabled, the relay is turned off if current exceeds the threshold
#   - Save Energy to Flash: enables persistent storage of energy counters
#   - Reset Energy Counters button
#   - Restart Device button
#   - All configurations are stored in flash and restored after power loss
# ENERGY MANAGEMENT
#   - Energy is calculated every second from instantaneous power
#   - Energy values are stored in RAM and optionally synchronized to flash
#   - Flash synchronization occurs every 10 minutes (when enabled)
#   - Daily energy resets automatically at local midnight using SNTP time (timezone dependent)
# SENSOR LOGIC & FILTERING
#   - Voltage is always sampled and averaged
#   - Current and power are sampled only when the relay is ON
#   - Load detection: measurements start only after a real electrical load is detected
#   - Burst mode is activated upon load detection:
#       For the first 3 seconds after load detection, raw values are published immediately for fast UI feedback
#   - After burst mode, values are averaged over the Scan Time interval and published only if they change beyond a defined threshold
# RELIABILITY FEATURES
#   - UART watchdog: stops measurements if the CSE7766 stops reporting data
#   - Restore from flash: Relay state (when selected). Configuration options, Energy counters (when enabled)
# Changelog
# Rev 2.0
#   - Major refactor of sensor processing and load detection logic
#   - Burst mode is now triggered only when a real electrical load is detected
#     (relay ON and power > ~1.8 W), not simply on relay activation
#   - Improved load detection to avoid phantom readings with relay ON and no load
#   - Voltage is now always sampled and averaged, even when relay is OFF
#   - Added separate voltage sample counter for more accurate averaging
#   - Improved burst publishing logic with load confirmation (burst_has_load)
#   - Initial voltage value is published at boot to avoid "Unknown" state in Home Assistant
#   - Added UART watchdog to reset measurements if CSE7766 data stalls while relay is ON
#   - Improved energy calculation using raw power readings from CSE7766
#   - Improved current estimation fallback (P/V) for very low current readings
#   - Better separation between burst phase and averaging phase (discard window)
#   - Improved flash synchronization logic and reduced unnecessary writes
#   - Improved stability and reliability during relay ON/OFF transitions
# Rev 1.3.2
#   - Offset changes are reflected immediately
#   - Improved initial burst mode
# Rev 1.3.1
#   - Fix voltage reporting with relay off
# Rev 1.3
#   - Added Local Timezone: Midnight reset occurs at local time (Europe/Rome).
esphome:
  friendly_name: "Test Powr2"
  on_boot:
    priority: 600.0
    then:
      - lambda: |-
          id(ocp_alarm).publish_state(false);
          auto index = id(relay_boot_mode).active_index();
          if (index == 0) {
            id(relay_switch).turn_off();
          } else if (index == 1) {
            id(relay_switch).turn_on();
esp8266:
  board: esp8285
  restore_from_flash: true
  early_pin_init: false
wifi:
  ssid: !secret wifi_ssid
  min_auth_mode: WPA2
  ap:
    ssid: hotspot_powr2
    password: !secret hotspot_wifi_password
captive_portal:
preferences:
  flash_write_interval: 3600s
globals:
  - id: v_sum
    type: float
    initial_value: '0.0'
  - id: v_sample_count
    type: int
    initial_value: '0'
  - id: i_sum
    type: float
  - id: p_sum
    type: float
  - id: sample_count
    type: int
    initial_value: '0'
  - id: seconds_elapsed
    type: int
    initial_value: '0'
  - id: discard_timer
    type: int
    initial_value: '0'
  - id: is_burst
    type: bool
    initial_value: 'false'
  - id: burst_has_load
    type: bool
  - id: load_detected
    type: bool
  - id: last_update_millis
    type: uint32_t
    initial_value: '0'
  - id: last_v_pub
    type: float
    initial_value: '-1.0'
  - id: last_i_pub
    type: float
  - id: last_p_pub
    type: float
  - id: global_energy_total_flash
    type: double
    restore_value: true
  - id: global_energy_daily_flash
    type: double
    restore_value: true
  - id: energy_total_ram
    type: double
  - id: energy_daily_ram
    type: double
api:
ota:
  - platform: esphome
    password: "dlkjghsjlkjb4634AA"
logger:
  level: WARN
  baud_rate: 0
uart:
  rx_pin: RX
  tx_pin: TX
  baud_rate: 4800
  parity: EVEN
time:
  - platform: sntp
    timezone: "Europe/Rome"
    on_time:
      - seconds: 0
        minutes: 0
        hours: 0
        then:
          - lambda: |-
              id(energy_daily_ram) = 0.0;
              id(global_energy_daily_flash) = 0.0;
              id(energy_today_display).publish_state(0.0);
              id(debounced_sync).execute();
script:
  - id: burst_logic
    mode: restart
    then:
      - lambda: |-
          id(is_burst) = true;
          id(burst_has_load) = false;
          id(discard_timer) = 3;
      - delay: 3s
      - lambda: |-
          id(is_burst) = false;
  - id: debounced_sync
    mode: restart
    then:
      - delay: 1s
      - lambda: |-
          if (id(energy_flash_save_enabled).state) {
            id(global_energy_daily_flash) = id(energy_daily_ram);
            id(global_energy_total_flash) = id(energy_total_ram);
          global_preferences->sync();
  - id: reset_ocp_alarm
    mode: restart
    then:
      - delay: 1s
      - lambda: 'id(ocp_alarm).publish_state(false);'
binary_sensor:
  - platform: gpio
    pin: { number: GPIO0, mode: INPUT_PULLUP, inverted: true }
    internal: true
    on_press:
      - switch.toggle: relay_switch
  - platform: cse7766
    voltage:
      internal: true
    current:
      internal: true
    power:
      internal: true
      on_value:
        then:
          - lambda: |-
              id(last_update_millis) = millis();
              float v_now = std::max(0.0f, id(voltage_raw).state + id(voltage_offset).state);
              float p_raw = std::max(0.0f, id(power_raw).state);
              float i_now = 0.0f;
              float p_now = p_raw;
              id(v_sum) += v_now;
              id(v_sample_count)++;
              if (id(relay_switch).state) {
                  i_now = std::max(0.0f, id(current_raw).state + id(current_offset).state);
                  if (p_now > 0.5f && i_now < 0.005f && v_now > 100.0f) i_now = p_now / v_now;
                  if (p_now >= 0.8f) {
                      if (!id(load_detected) && p_now > 1.8f) {
                          id(load_detected) = true;
                          id(i_sum) = 0.0; id(p_sum) = 0.0;
                          id(sample_count) = 0; id(seconds_elapsed) = 0;
                          id(burst_logic).execute();
              if (id(is_burst)) {
                  if (i_now > 0.01f || id(burst_has_load)) {
                      id(burst_has_load) = true;
                      id(voltage_avg).publish_state(v_now);
                      id(current_avg).publish_state(i_now);
                      id(power_avg).publish_state(p_now);
                      id(last_v_pub) = v_now; id(last_i_pub) = i_now; id(last_p_pub) = p_now;
              if (id(discard_timer) == 0 && id(load_detected)) {
                id(i_sum) += i_now;
                id(p_sum) += p_now;
                id(sample_count)++;
    unit_of_measurement: V
    device_class: voltage
    state_class: measurement
    accuracy_decimals: 1
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    unit_of_measurement: W
    device_class: power
    unit_of_measurement: kWh
    device_class: energy
    state_class: total_increasing
  - platform: uptime
  - platform: wifi_signal
    name: "WiFi Signal dB"
number:
    entity_category: config
    min_value: 1
    max_value: 60
    step: 1
    unit_of_measurement: "s"
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 5
    on_value:
      then:
        - script.execute: debounced_sync
    min_value: -10.0
    max_value: 10.0
    step: 0.1
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 0.0
    on_value:
      then:
        - lambda: |-
            float v_now = id(voltage_raw).state + x;
    min_value: -1.000
    max_value: 1.000
    step: 0.001
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 0.000
    on_value:
      then:
        - lambda: |-
            float i_now = std::max(0.0f, id(current_raw).state + x);
    name: "Max Current Threshold"
    min_value: 0.0
    max_value: 15.0
    step: 0.1
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 15.0
    on_value:
      then:
select:
    options: ["Off", "On"]
    restore_value: true
    optimistic: true
    on_value:
      then:
    options: ["Always Off", "Always On", "Restore Previous"]
    restore_value: true
    initial_option: "Restore Previous"
    optimistic: true
    on_value:
      then:
button:
    name: "Reset Energy Counters"
    on_press:
      then:
        - lambda: |-
            id(energy_daily_ram) = 0.0; id(energy_total_ram) = 0.0;
            id(global_energy_daily_flash) = 0.0; id(global_energy_total_flash) = 0.0;
            id(energy_today_display).publish_state(0.0); id(energy_total_display).publish_state(0.0);
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      - lambda: |-
          id(last_i_pub) = -1.0; id(last_p_pub) = -1.0;
          id(load_detected) = false;
      - script.execute: burst_logic
    on_turn_off:
      - script.stop: burst_logic
      - lambda: |-
          id(is_burst) = false; id(burst_has_load) = false;
          id(load_detected) = false; id(discard_timer) = 0;
          id(current_avg).publish_state(0.0); id(power_avg).publish_state(0.0);
          id(last_i_pub) = 0.0; id(last_p_pub) = 0.0;
          id(i_sum) = 0.0; id(p_sum) = 0.0; id(sample_count) = 0;
    name: "Overcurrent Protection"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
    on_turn_off:
    name: "Save Energy to Flash"
    optimistic: true
    on_turn_on:
    on_turn_off:
  - platform: restart
output:
  - platform: esp8266_pwm
    pin: { number: GPIO13, inverted: true }
interval:
  - interval: 1s
    then:
      - lambda: |-
          static bool init_done = false;
          if (!init_done) {
            id(energy_total_ram) = id(global_energy_total_flash);
            id(energy_daily_ram) = id(global_energy_daily_flash);
            init_done = true;
          if (id(relay_switch).state && (millis() - id(last_update_millis) > 1000)) {
              id(last_p_pub) = 0.0; id(last_i_pub) = 0.0;
          static bool first_boot_pub = false;
          if (!first_boot_pub && id(voltage_raw).has_state()) {
              float v_start = id(voltage_raw).state + id(voltage_offset).state;
              id(voltage_avg).publish_state(v_start);
              id(last_v_pub) = v_start;
              if (id(relay_switch).state && !id(load_detected)) {
              first_boot_pub = true;
          float p_now_energy = 0.0;
            float v_e = std::max(0.0f, id(voltage_raw).state + id(voltage_offset).state);
            float p_e = std::max(0.0f, id(power_raw).state);
            float i_e = std::max(0.0f, id(current_raw).state + id(current_offset).state);
            if (p_e > 0.5f && i_e < 0.005f && v_e > 100.0f) i_e = p_e / v_e;
            p_now_energy = p_e;
            if (id(overcurrent_enabled).state && i_e > id(max_current_threshold).state) {
               id(ocp_alarm).publish_state(true);
               id(reset_ocp_alarm).execute();
          if (p_now_energy > 0.5f) {
            double delta_e = ((double)p_now_energy * 1.0) / 3600000.0;
            id(energy_total_ram) += delta_e;
            id(energy_daily_ram) += delta_e;
          static uint32_t last_energy_sync = 0;
          if (millis() - last_energy_sync > 600000) {
              last_energy_sync = millis();
              if (id(energy_flash_save_enabled).state) id(debounced_sync).execute();
          if (id(discard_timer) > 0) id(discard_timer)--;
          if (!id(is_burst)) id(seconds_elapsed)++;
          if (!id(is_burst) && id(seconds_elapsed) >= (int)id(interval_input).state) {
            if (id(v_sample_count) > 0) {
                float avg_v = id(v_sum) / (float)id(v_sample_count);
                if (abs(avg_v - id(last_v_pub)) >= 0.1f) {
                    id(voltage_avg).publish_state(avg_v);
                    id(last_v_pub) = avg_v;
                id(v_sum) = 0.0f; id(v_sample_count) = 0;
            if (id(sample_count) > 0) {
                float avg_i = id(i_sum) / (float)id(sample_count);
                float avg_p = id(p_sum) / (float)id(sample_count);
                if (abs(avg_i - id(last_i_pub)) > 0.001f) { id(current_avg).publish_state(avg_i); id(last_i_pub) = avg_i; }
                if (abs(avg_p - id(last_p_pub)) > 0.1f) { id(power_avg).publish_state(avg_p); id(last_p_pub) = avg_p; }
            static float last_e_today_pub = -1.0;
            static float last_e_total_pub = -1.0;
            float e_today = (float)id(energy_daily_ram);
            float e_total = (float)id(energy_total_ram);
            if (abs(e_today - last_e_today_pub) > 0.001f) { id(energy_today_display).publish_state(e_today); last_e_today_pub = e_today; }
            if (abs(e_total - last_e_total_pub) > 0.001f) { id(energy_total_display).publish_state(e_total); last_e_total_pub = e_total; }
  - interval: 500ms
    then:
      - lambda: |-
          static int tick = 0; tick++;
          bool connected = wifi::global_wifi_component->is_connected();
          if (!connected) id(led_output).set_level((tick % 2 == 0) ? 1.0 : 0.0);
          else id(led_output).set_level((id(led_behavior).active_index() == 1) ? 1.0 : 0.0);
Hi @firstcolle,
thank you for your work. Today, I have flashed my Sonoff POWR2 with ESPHome. After that, I stumbled accross your post here. Great work. I will have a closer look at it and see, where I could improve my yaml.
There is one question, I am struggling with: when updating any of my Sonoff devices, they reboot, but there is no break in power supply. When updating the same Sonoff devices with ESPHome, it toggles the relay. In most of the cases, this is not an issue, but in my case, I measure the power consumption of my IT infrastructure: router, gateway, switch, access points, NAS, server with docker, …
especially my server with the docker containers and DBs don’t like suppen loss of power.
Is there a way around that? Can I configure ESPHome to keep the power supply open, even when updating?
Thanks,
Chris
Maybe. The POW2 uses GPIO12 to control the relay. The default at reset for GPIO12 is input mode so effectively LOW/zero/OFF for the relay.
You can try using restore mode:
That might help, but the relay will likely glitch during an update/restart. Depending on what you have connected it might or might not notice.
Years ago, people used to short the relay contacts to prevent it from turning off. Shelly makes power monitoring nodes that don’t even have a relay so that is an option too.
I have my critical infrastructure on a UPS, so that is yet another option with additional advantages.
I have found something in the ESPHome documentation:
early_pin_init (Optional, boolean): Specifies whether pins should be initialised as early as possible to known values. Recommended value is false where switches are involved, as these will toggle when updating the firmware or when restarting the device. Defaults to true.
Source: ESP8266 Platform - ESPHome - Smart Home Made Simple
Do you think, this will help to prevent toggle of the relay while updating?
esp8266:
  board: esp01_1m
Update: I added the early_pin_init:false and your recommendation to the code.
switch:
  - platform: gpio
    pin: GPIO12
I have connected the Sonoff POWR2 to my desktop lamp and it did not flicker and I did not hear the relay click. Fingers crossed, that this works. :crossed_fingers:
Glad it’s working for you. I don’t put my critical infrastructure on a switch. It isn’t worth the risk to me. Most of it is on UPS power for the inevitable failures.
added also in my code!
