Custom Geo-Location events from traccar
Hello All,
I wanted to create a custom tracker that points within the MAP where i turned on/off the car. I have an integration with traccar server which i have configured to forward events from via a webhook. From there i listen for an event of ignition on/off and then update a custom device tracker with the geo-location. What i discovered when i look at the map is that it draws lines between the locations and does not just drop pins on the map of the event happening location. Any help on this topic is highly appreciated.
That sounds odd.
Would you be able to share a screenshot of the map and the details of the device tracker status including attributes with us (blur/anonymise if necessary to protect your privacy)?
Attached is a sample:
Basically I dont want the line between the dots. I just want the dots location with the tracker name on top of them not sure whether this is possible or not.
Regards.
