Custom:home-feed card Configuration error
I started getting a “Configuration Error” for all 3 of my home-feed cards. Everything looks fine, I’ve compared with the latest documentation and it all looks good.
Here its my frontend code:
type: horizontal-stack
theme: kibbit
cards:
  - type: vertical-stack
    cards:
      - type: custom:home-feed-card
        title: Family & School
        calendar_time_format: datetime
        card_id: fam_feed
        show_empty: true
        calendar_days_forward: 10
        calendars:
          - calendar.family_school
        id_filter: ^home_feed_.*
        more_info_on_tap: true
        state_color: true
        title: Movie Night
        card_id: mv_feed
        show_empty: true
        calendar_days_forward: 7
        calendars:
          - calendar.movie_night
        state_color: true
        title: Vacations
        card_id: vac_feed
        show_empty: true
        calendar_days_forward: 365
        calendars:
          - calendar.vacations
        state_color: true
        theme: transparentblue
      - type: entities
        entities:
          - entity: group.vacation_automations
            icon: mdi:beach
    cards:
      - show_state: true
        show_name: true
        camera_view: auto
        type: picture-entity
        image: https://demo.home-assistant.io/stub_config/bedroom.png
        entity: camera.front_door
      - type: entities
        entities:
          - entity: binary_sensor.front_door_motion
          - entity: sensor.front_door_last_activity
          - entity: sensor.front_door_last_motion
          - entity: sensor.front_door_last_ding
          - entity: sensor.front_door_battery
        show_header_toggle: false
        state_color: true
    cards:
      - type: entities
        title: Lawn Watering
        entities:
          - type: custom:fold-entity-row
            style: |
              :host {
                --state-icon-color:
                {% if states('valve.backyard_timer_zone') | lower == 'on' %}
                    rgb(245, 195, 68);
                {% else %}
                  white;
                {% endif %}
            head: valve.backyard_timer_zone
            icon: mdi:water-pump
            state_color: true
            entities:
              - entity: switch.backyard_timer_rain_delay
                style: |
                  :host {
                     --state-icon-color:
                     {% if states('switch.backyard_timer_rain_delay') | lower == 'on' %}
                         rgb(245, 195, 68);
                     {% else %}
                       white;
                     {% endif %}
              - entity: sensor.last_backyard_watering_start
                icon: mdi:water-circle
              - entity: sensor.last_backyard_watering_runtime
                type: custom:secondaryinfo-entity-row
                icon: mdi:timelapse
                toggle: true
              - entity: sensor.total_backyard_water_amount
              - entity: sensor.backyard_timer_battery_level
                icon: mdi:battery-50
            head: valve.front_yard_timer_zone
            state_color: true
            style: |
              :host {
                 --state-icon-color:
                 {% if states('valve.front_yard_timer_zone') | lower == 'on' %}
                     rgb(245, 195, 68);
                 {% else %}
                   white;
                 {% endif %}
            entities:
              - entity: switch.lawn_timer_rain_delay
                toggle: false
                style: |
                  :host {
                     --state-icon-color:
                     {% if states('switch.lawn_timer_rain_delay') | lower == 'on' %}
                         rgb(245, 195, 68);
                     {% else %}
                       white;
                     {% endif %}
              - entity: sensor.last_watering_start
              - entity: sensor.last_watering_runtime
                icon: mdi:timelapse
                toggle: true
              - entity: sensor.total_lawn_water_amount
              - entity: switch.lawn_timer_morning_program
                secondary_info: '{{states(''sensor.next_morning_lawn_run'')}}'
                style: |
                  :host {
                     --state-icon-color:
                     {% if states('switch.lawn_hose_tap_timer_morning_program') | lower == 'on' %}
                         rgb(245, 195, 68);
                     {% else %}
                       white;
                     {% endif %}
              - entity: switch.lawn_timer_mid_day_program
                name: Mid Day Program
                style: |
                  :host {
                     --state-icon-color:
                     {% if states('switch.lawn_timer_mid_day_program') | lower == 'on' %}
                         rgb(245, 195, 68);
                     {% else %}
                       white;
                     {% endif %}
                secondary_info: '{{states(''sensor.midday_watering_start'')}}'
              - entity: switch.lawn_timer_evening_program
                style: |
                  :host {
                     --state-icon-color:
                     {% if states('switch.lawn_timer_evening_program') | lower == 'on' %}
                         rgb(245, 195, 68);
                     {% else %}
                       white;
                     {% endif %}
                secondary_info: '{{states(''sensor.next_evening_lawn_run'')}}'
              - entity: sensor.lawn_timer_battery_level
          - entity: input_boolean.start_watering
            toggle: true
            state_color: true
            show_toggle: true
            theme: kibbit
      - type: entities
        entities:
          - entity: climate.thermostat
            name: Current Thermostat Setting
            toggle: false
            icon: mdi:home-thermometer
          - entity: weather.thermostat
            name: Outside Conditions
            icon: mdi:weather-cloudy
          - entity: sensor.thermostat_temperature
            icon: mdi:thermometer
          - entity: sensor.thermostat_humidity
            icon: mdi:water-percent
            toggle: true
Here is what I have in configuration.yaml:
calendar:
  - platform: caldav
    username: !secret icloud_login
    password: !secret icloud_password
    url: https://caldav.icloud.com
    calendars:
      - "Family & School"
      - "Movie Night"
      - "Vacations"
