[Custom Integration] Camp Chef – Local BLE pellet grill integration
Hi all,
I’m sharing a new custom Home Assistant integration for Camp Chef–family pellet grills
(Camp Chef, Cabela’s, Kingsford) that communicates locally over Bluetooth Low Energy (BLE).
The goal is simple: cloud-free monitoring and control of compatible grills directly from Home Assistant.
Key features
  • Local BLE control (no cloud dependency)
  • UI-based config flow with Bluetooth discovery
  • Automatic capability detection (probes, features vary by model)
  • Hybrid push (notifications) + polling update model
  • Diagnostic and high-churn entities are disabled by default
Entities
  • Climate: grill chamber temperature (current & target)
  • Sensors: grill mode, pellet level, probe temperatures, Wi-Fi RSSI/SSID,
    OTA state & progress
  • Binary sensor: Wi-Fi connectivity (diagnostic)
  • Fault / transitioning / fan entities are available but disabled by default
Bluetooth notes
  • Uses Home Assistant’s built-in Bluetooth stack
  • No custom pairing UI is provided
  • Grills that require bonding should be paired once at the OS level (e.g. via bluetoothctl on HAOS)
When BLE notifications are available, updates are near real-time.
If notifications aren’t supported by the Bluetooth backend (for example when using an ESPHome Bluetooth Proxy),
the integration automatically falls back to polling.
Repo:
Status
This is an early release and I’m looking for:
  • Feedback on supported models / firmware
  • Reports on Bluetooth reliability across different setups
  • Suggestions before pursuing upstream inclusion
This project is not affiliated with or endorsed by Camp Chef or related brands.
Happy to answer questions or take feature requests. Thanks!
Been waiting for one of these to pop up! I’ll definitely be a tester.
