Custom Integration for BetaSeries
Hello everyone.
I’ve developed a Home Assistant integration for BetaSeries.
If you track your TV shows on BetaSeries, this integration brings the information directly into Home Assistant.
You can view your watchlist, receive notifications for new episodes, check a schedule, mark episodes as watched, or rate them.
What it exposes:
  • Episodes to watch
  • Shows to catch up on
  • Today’s suggestion
  • Programming schedule
  • Upcoming episodes
  • Additional sensors for automations
You need to create an API app on betaseries.com/api.
Then it’s straightforward: HACS or manual installation, then add the integration.
Two authentication methods: device code or login/password.
Interface available in French and English.
If you have suggestions, bugs to report, or use cases you’d like to see, go ahead.
The complete list of entities is available in the documentation.
Repo: GitHub - bastgau/ha-betaseries: 🎞️ The BetaSeries integration for Home Assistant lets you monitor your BetaSeries account directly from Home Assistant. · GitHub
