Introduction
Text-to-speech (TTS) is a useful feature in home automation, allowing systems to generate spoken announcements and notifications. OpenTTS is an open-source service supporting multiple speech synthesis backends, including Google TTS, Microsoft Azure, and Piper.
The ha_opentts_integration is a Home Assistant custom integration that enables OpenTTS support. This approach is based on a legacy technique, and it is unclear whether similar implementations exist.
This integration builds on the work of OpenTTS by Synesthesiam, which provides a flexible TTS solution supporting multiple backends. OpenTTS serves as the foundation for this implementation, making it possible to use various speech synthesis engines within Home Assistant.
Why OpenTTS?
OpenTTS provides multiple speech synthesis backends and can be used locally or with cloud-based services. It allows for flexibility in choosing TTS voices while maintaining control over privacy settings.
Features of ha_opentts_integration
This integration:
- Enables OpenTTS support in Home Assistant
- Allows configuration of language, voice, and speed settings
- Works with different TTS engines through OpenTTS
- Supports media players for spoken notifications
- Requires minimal configuration
How to Install
To set it up:
Download the Integration
Clone or download the repository from GitHub:git clone https://github.com/RoyOltmans/ha_opentts_integration
Place the Integration in Home Assistant
Move theha_opentts_integration
folder into thecustom_components
directory. -
Restart Home Assistant
Reload Home Assistant for the integration to be recognized. -
Configure OpenTTS
Add the following lines toconfiguration.yaml
:tts: - platform: opentts url: "http://your-opentts-server:5500"
Replace
your-opentts-server
with the correct IP or hostname. -
Test the Integration
Execute a simple script to check OpenTTS output:service: tts.opentts_say data: entity_id: media_player.living_room_speaker message: "This is OpenTTS in Home Assistant."
Considerations
This integration relies on a legacy technique, and its long-term viability is uncertain. It is unknown if similar solutions exist or if this is the first implementation of its kind.
If you have feedback, suggestions, or want to contribute, visit the project repository: ha_opentts_integration.
