Hi everyone,
I would like to share a custom Home Assistant integration for customers of Tauron Dystrybucja in Poland.
The integration retrieves planned and unplanned power outages for a configured address using Tauron’s publicly available web API.
GitHub repository:
Features
For each configured address, the integration creates:
- an outage status sensor:
- No outages
- Outage announced
- Outage in progress
- outage start and end timestamp sensors
- outage duration sensor
- full outage description
- a counter showing the number of announced outages in the next 30 days
- a calendar entity containing all known outages
- an event entity triggered whenever Tauron announces a new outage
- a binary sensor that is active while an outage is in progress
You can configure multiple addresses by adding the integration more than once.
Dashboard example
The data can be displayed using standard Home Assistant cards or a Markdown card showing all upcoming outages:
[UPLOAD SCREENSHOT HERE]
The screenshot above shows several planned outages together with:
- date and time
- relative information such as “tomorrow” or “in 3 days”
- the complete list of affected streets and house numbers
Automations
The integration can be used to create notifications when:
- Tauron publishes a newly announced outage
- an outage is about to start
- an outage is currently in progress
For example, you can receive a mobile notification one day or two hours before the power is switched off.
Installation
The integration is currently waiting for review in the default HACS repository.
Until then, it can be installed as a custom HACS repository:
Open HACS
Go to the three-dot menu
Select Custom repositories
Add:
https://github.com/Eales/tauron-dystrybucja -
Select the Integration category
Install Tauron Dystrybucja
Restart Home Assistant
After installation:
- Go to Settings → Devices & Services
- Select Add Integration
- Search for Tauron Dystrybucja
- Select the city and street
- Enter the house number
The polling interval can be configured between 15 and 1440 minutes. The default is 60 minutes.
Requirements
Home Assistant 2024.11.0 or newer.
Notes
Tauron sometimes returns outages for a wider geographical area. Therefore, the outage description should always be checked because it contains the actual streets and house numbers affected by the works.
The integration is open source and released under the MIT licence.
Feedback, bug reports and pull requests are very welcome.
