Custom Integration: TP-Link easy smart switch monitor
A Home Assistant integration to monitor single port bandwidth usage on TP-Link Easy Smart Switches.
:heavy_check_mark: Real-time bandwidth monitoring (RX/TX Mbps)
:heavy_check_mark: Works with TP-Link TL-SG1016DE, TL-SG108E, and similar models
:heavy_check_mark: Configurable polling interval & MTU
:heavy_check_mark: Home Assistant UI-based setup (no YAML required!)
Installs with HACS as custom repository.
