I just made an integration for ZyXEL devices. If you don’t know, they make network hardware like routers, switches etc.
The integration was built for, and tested on, a ZyXEL NR7101 which is a 5G modem/router. It will likely work on other devices if they share the same API.
Hi!
I would like to ask you a question to you who use this router.
You can send SMS from Home Assistant via shell_command.
I have a Teltonika router, and from Home Assistant via a shell command I can send an SMS from the 4G router to my smart phone (for example if Alarmo is triggered, Home Assistant tells the router to send an SMS to me)
Hi! Sorry, what is the question? You want to know if it is possible to send SMS with this brand/model of router?
I don’t know, but I don’t think so. I don’t see this option anywhere in the router’s interface.
I’m just a beginner at ha and would like to ask a question. I use 5 Zyxel Access Points, they are configured with nebula cloud (control center). So I have a login for the cloud, but not an IP oder Login for a host. How can I use the integration?
It won’t work with Nebula credentials.
I don’t know how Nebula works, but surely there is a way to connect locally?
What is written on the back of your devices?
As arobaZ says: The default local login is on the backside of the device.
Pray that someone else did not change them.
When you set up the account at Nebula, you choose to either keep this local login or use the Nebula cloud credentials.
I am using Nebula cloud, the cloud credentials, and HA Zyxel integration. It works.
As I understand it, if local credentials are used and someone changed them, you will have to hard-reset the device to make the backside-printed admin/passwd re-appear.
Hard-resetting will reset any DHCP and whatever other settings. To be avoided, if you can. Installing my Zyxel FW710 antenna with router is a nightmare.
