Custom intents conflict easily with built in intents
Hi All,
I’ve been battling away trying to get custom intents working as I want to be able to say “Play X on Y in Z” and really constraint what Y and Z are.
My intent “works” if i put something unique in it like “abracadabra Play X on Y in Z” :smiley: however without that uniquness, i easily clash with HassMediaSearchAndPlay which seems to have template sentenses for all sorts.
I suppose what I’m looking for is the ability to some how rank my custom intents more highly than the default ones, or even turn the default ones off, but I cannot find any way to do this.
Apologies if this is a dumb question, I’m reasonably new to custom intents.
Are you using llm or speech to phrase builtin assist without llm or resolve local first (need to know which problem were solving)
I played around a fair bit with customs and sentence triggers earlier in the year and have forgotten some of this, but looking back at some notes I made, here are a couple of thoughts:
  • If both a Sentence Trigger and a built-in intent matches, the Sentence trigger action seems to take precedence. So maybe try a sentence trigger.
  • I have written what is called an “extension” to an existing built-in response (an extension is a custom that uses the same name as the built-in) and found that my custom response actions are run instead of the built-in ones. So if HassMediaSearchAndPlay match the intents you like, but you want a different action(s), you can try this method.
  • Here is one I have not tried. You may want to try to “extend” the existing HassMediaSearchAndPlay built-in intent. Normally the “extended” intent is not suppose to conflict with the built-in one, just “extends” it. However try and see what happens when your custom extension intent of HassMediaSearchAndPlay matches the built-in intents and see if yours takes precedence.
