Custom Lovelace card - hacs install - file copy problem
Hi
I’m creating a card and I’m having a problem because after installing it through HACS, the png file is not being copied.
file structure:
/hacs.json
/thesslagreen-card.js
/reku.png
can any of you take a look? I have an idea for a cool card and I’m just starting :stuck_out_tongue:
hacs.json
  "name": "Thessla Green Custom Card",
  "content_in_root": true,
  "render_readme": true,
  "filename": "thesslagreen-card.js",
  "homeassistant": "2023.9.0",
thesslagreen-card.js:
class ThesslaGreenCard extends HTMLElement {
  setConfig(config) {
    this._config = config;
  set hass(hass) {
    if (!this.content) {
      const card = document.createElement('ha-card');
      card.style.position = 'relative';
      card.style.overflow = 'hidden';
      const background = document.createElement('img');
      background.src = '/local/community/thesslagreen-card/reku.png';
      background.style.width = '100%';
      background.style.display = 'block';
      // Kontener na elementy
      const elementsContainer = document.createElement('div');
      elementsContainer.style.position = 'absolute';
      elementsContainer.style.top = 0;
      elementsContainer.style.left = 0;
      elementsContainer.style.width = '100%';
      elementsContainer.style.height = '100%';
      // Przykładowy element (np. czujnik)
      const el = document.createElement('div');
      el.innerText = '🔥';
      el.style.position = 'absolute';
      el.style.top = '40%';
      el.style.left = '60%';
      el.style.fontSize = '2rem';
      elementsContainer.appendChild(el);
      card.appendChild(background);
      card.appendChild(elementsContainer);
      this.appendChild(card);
      this.content = card;
  static get styles() {
    return css`
      ha-card {
        padding: 16px;
        box-sizing: border-box;
customElements.define('thessla-green-card', ThesslaGreenCard);
window.customCards = window.customCards || [];
window.customCards.push({
  type: 'thessla-green-card',
  name: 'Thessla Green Card',
  preview: false,
  description: 'Custom picture-elements-like card for Thessla Green integration'
next to these files I have a reku.png file on the repo but after installing with hacs this file does not appear in the folder /www/community/thesslagreen-card/
there is only the thesslagreen-card.js file
