Custom occupancy Sensor for Car Detection
Hi all,
i’ve a little ESP8266 (with ESPHome) on my Car parking where i’m using two SR04T sensors. The current configuration is this one:
  sensors:
    my_car:
      friendly_name: "My Car"
      device_class: occupancy
      icon_template: >
        {% if is_state("sensor.sensore_auto_mia", "unknown") %}
        mdi:car-off
        {% else %}
        mdi:car
        {% endif %}
      value_template: >-
        {{ states('sensor.sensore_auto_mia')|float < 1 }}
    wife_car:
      friendly_name: "Wife Car"
      icon_template: >
        {% if states('sensor.sensore_auto_moglie')|float > 1 %}
        mdi:car-off
        {% else %}
        mdi:car
        {% endif %}
      value_template: >-
        {{ states('sensor.sensore_auto_moglie')|float < 1 }}
The problem is with the sensor sensor.sensore_auto_mia, because without the car under the sensor ESPHome report the value to Uknown instead of a real measure.
Most of the time, the reading of this sensor is false (i’ve to check the real item sensor instead of template sensor to check if car is on place or not).
Any hints?
Thanks!
Please format your post correctly.
is it ok now?
thanks
Yep. Much better.
What sort of sensor?
Can we see the esphome config?
here is the ESPHome configuration:
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "REMOVED"
  password: "REMOVED"
  reboot_timeout: 15s
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: D6
      inverted: True
      mode: INPUT_PULLUP
    on_press:
      then:
        - switch.turn_on: relay_1
    on_release:
      then:
        - switch.turn_off: relay_1
switch:
  - platform: gpio
    pin: D5
  - platform: restart
  - platform: ultrasonic
    trigger_pin: D1
    echo_pin: D0
    update_interval: 5s
    name: "Sensore Auto Moglie"
    trigger_pin: D3
    echo_pin: D2
    update_interval: 5s
    name: "Sensore Auto Mia"
  - platform: uptime
  - platform: wifi_signal
    name: "Segnale WiFi ESP02"
    update_interval: 60s
text_sensor:
  - platform: version
logger:
