Custom sensor not visible
I’m new to HA, and I’m trying to create my first custom sensor, just the substraction of two sensor values.
I have added the following code to developer/templates:
template:
  - sensor:
      - name: Sensor de Consumo
        unit_of_measurement: W
        state: "{{ states('sensor.inverter_active_power')|float(0) - states('sensor.power_meter_active_power')|float(0)}}"
#        state_class: "measurement"
#        unique_id: energy_current_usage_power_sensor
#        device_class: current
#        icon: "mdi:power"
#        friendly_name: "Sensor de Consumo"
I can see the following in the right side:
template:
  - sensor:
      - name: Current Power Usage
        state: "513.0"
#       unique_id: energy_current_power_usage_sensor
#       icon: "mdi:power"
513 is a reasonable value for that sensor in the moment I’m doing this.
The problem is I cannot see the sensor at all, neither under devices, nor under entities. I can’t add it to a entities card in a panel, I can’t use it as trigger in automation. etc. It’s like it doesn’t exist.
I already restarted HA, and also I have tried to add that code directly to configuration.yaml and restart HA (no errors found on boot after I fixed a typo), but no way, it doesn’t appear.
Am I missing something?
Thanks!
PS: I’m using HA via a docker image running on a Synology NAS, in case it matters.
PS2: I’ve already checked other posts with more or less similar problems, and tried everything I saw on them, the code above is a curated version of my original code, but still doesn’t work :frowning:
The code should go in configuration.yaml . developer/templates is just for testing templates.
Thanks. Understood, but it doesn’t work in configuration.yaml either.
You will need to go into developer tools /yaml and click on template entities at the bottom to reload your new sensor entity.
That was it, it’s working now. Many thanks!
