I’m renovating my house and I wanted to drop the old thermostats and use something smarter. I live in Italy.
My setup:
- underfloor water heating
- samsung heating pump (external unit)
- samsung hydro module (internal unit)
- Actuator Valves 230v (on/off)
I was thinking of going with:
- Aqara Temperature and Humidity sensor (Temperature and Humidity Sensor - Aqara)
- Shelly 1 gen4 to open or close the actuator based on the room’s temp.
- optional: do something with humidity values and the controlled mechanical ventilation unit (TODO for the future)
My questions:
- would this setup work fine as smart thermostat?
- would you suggest other sensors? I like the Aqara because it supports Mattter and HA officially.
- should I setup a simple hysteresis for the thermostat (e.g. tolerance -1C, +1C) or should I build some more complex logic like PID or PID+PWM (simulated via software since I have only on/off actuators). I was thinking simple hystersis since the underfloor water heating is something that one set and leave it as is.
