Hello HA community,
I have done some research, but not find a solution what is recommended for HA about the following.
Wish:
- Use current physical dumb switch
- After 18:55 i would the lights at 50% brightness.
- Before 18:55 the brightness can stay at 100%.
- Natural White (Not blue white)
- Zigbee.
My current light setup.
A: Four Tradfiri (on/off, dimmable, white/yellow) bulbs connected to a dumb switch.
(added to HA Zigbee2Mqtt).
Problem: If these bulbs are on, than brightness, on/off state, yellow/white can be controlled. This cannot be changed if they are off. Last settings are being remembered.
B: Four Eglo ceiling lamps
(Not dimmable, attached to dumb switch).
Two off these ceilings controlled by KlikaanKlikUit
- In both ceiling light added a ACM-2000.
- Physical dumb switch is removed, (someone has hardwired the wires), so it
only be controlled by the remote rf double physical switch (awst-8802).
The other two are only connected to a physical dumb switch.
Possible options?:
Adaptive lightning, not tested yet. But I want to specify my own simple settings, I am carefull adding something to HA without breaking it.
HA Scenes, I cannot adjust brightness entity, because these not exist.
For B:
Physical Switch → Zigbee Dimmer Switch (Moes? or Tuya Zigbee) →
compatible zigbee dimmer led driver. -
Maybe in the future a extra zigbee remote only for brightness or with also on or off.
