I really like the mushroom-light-card (top row) that act as a switch as well as a slider.
Now I have a switch (Pump) and a slider that is acutally a helper (Duration) in the lower two rows (yaml code below):
Is there an easy way to combine switch and slider below into the same look as the above displayed mushroom-light-card?
I would appreciate your help.
Best,
pamkkl
type: custom:mushroom-light-card
entity: light.switch_light
fill_container: true
show_brightness_control: true
grid_options:
rows: 2
columns: full
secondary_info: none
square: true
type: grid
cards:
- show_name: true
show_icon: true
type: button
entity: switch.pump_l1
icon: mdi:water-pump
theme: Mushroom
tap_action:
action: call-service
service: input_boolean.toggle
entity_id: input_boolean.pump_triggered_per_ui
visibility:
- condition: state
entity: automation.front
state: "on"
columns: 4
grid_options:
columns: full
square: true
type: vertical-stack
cards:
- type: custom:mushroom-number-card
entity: input_number.manual
visibility:
- condition: state
state: "on"
columns: 4
grid_options:
columns: full
