Custom UVC Camera Proxy Config
It seems like the UVC camera integration uses Camera Proxy internally.
The settings it uses internally gives low frame rate video streams which is not always desirable.
Would be good to be able to define your own camera proxy and then add it to the camera’s config to override the default camera proxy.
Tried creating a camera proxy for the UVC camera but that throws a whole lot of errors and does not work (assuming creating a proxy of a proxy is what’s happening and that doesn’t work).
Any update on this - yes its about 0.1s refresh rate from what i see. Would be nice to be able to modify.
I have the same problem - around 1fps.
