If the card isn’t displaying it means you are missing a required entity. This can be because you misspelled one or could also be that you are passing one that doesn’t exist. (Classic is pressure)
Check all entities in the lovelace card actually exist in dev tools. If you still can’t find it, PM me your card config, weather.yaml and location (lat/long) and I will add your config to my dev instance and see where your error is.
I am very new to HA, only having installed it a couple of days ago. I’ve installed HACS, the custom component and added the Bureau of Met integration. When I try and add the bom-weather-card, I get an error saying “Respository ‘davidfw1960/bom-weather-card’ exists in the store”. When I search for “weather” or “generic” or “bom” etc, in the HACS frontend there is no trace of the card. I have restarted HA, I have emptied the cache and performed a hard reload and refreshed the page multiple times. Help?
Sorry for my ignorance (L plates), so in HACS>Frontend I click on “Explore & Download Repositories”, type “Custom Animated Weather Card” (actually only typed “custom ani”) and I get “No repositories found matching your filter”.
I’ll also note, I can’t see the custom animated weather card assets in my config (www/community or in custom_components/ or hacs/ - and its pretty empty in there as this is a fresh install of HA).
The BoM techs are pretty good. They should be on to it soon.
I’m friends with one of the techs that looks after the instruments in Tas and he’s usually aware if something has gone wrong before I ask him to hurry up and fix it
