Customization Not Working for Some Entities
For some reason, I am unable to customize some entities in Home Assistant, including the icon, friendly name, and ‘hidden’ attribute. There are no errors or warnings in the homeassistant log file.
For example, I want to hide both Trip A and Trip B sensors from the UI entirely:
Selection_030
Here is how I include the customizations:
homeassistant:
    customize: !include_dir_merge_named customize
And in the file customize/sensors.yaml:
sensor.c71e5d401fbf11e795090050568f5b13_trip_a:
  hidden: true
sensor.c71e5d401fbf11e795090050568f5b13_trip_b:
  hidden: true
Both of these entities are found in the states list:
And using the ‘built in’ customization UI at https://localhost/config/customize it is able to correctly parse the config and show that ‘Hide from UI’ is checked - so why isn’t it applied to the dashboard?
Selection_032
Also weird is that I have multiple other customizations in that file, changing both ‘hidden’ and the friendly name, and those changes are applied correctly. And this is just one example - I have about six or seven other sensors/switches having the same issues, even after multiple reboots.
customize: !include_dir_merge_named customize/sensors.yaml <===
Isn’t include_dir_merge_named supposed to be used with a directory argument, not a file argument? This is what the customize directory looks like:
customize/
├── binary_sensors.yaml
├── locks.yaml
├── sensors.yaml
└── switches.yaml
Advanced Usage
We offer four advanced options to include whole directories at once.
!include_dir_list will return the content of a directory as a list with each file content being an entry in the list.
!include_dir_named will return the content of a directory as a dictionary which maps filename => content of file.
!include_dir_merge_list will return the content of a directory as a list by merging all files (which should contain a list) into 1 big list.
!include_dir_merge_named will return the content of a directory as a dictionary by loading each file and merging it into 1 big dictionary.
I appreciate the response but I am already using include_dir_merge_named and, as far as I know, using it correctly.
I tried your suggestion of customize: !include_dir_merge_named customize/sensors.yaml and it did not work.
you can just put
!include customize/sensors.yaml <== this point specific to sensors.yaml in customize folder
That did not work either. I get the exact same behavior as before. Below is the full contents of my sensors.yaml file. Only the sensors beginning with sensor.c71e5d401fbf11e795090050568f5b13* are missing the customizations. Every other sensor in the configuration file is being applied properly.
sensor.aeotec_zw096_smart_switch_6_current:
  friendly_name: 'Bedroom Fan Current'
  hidden: true
sensor.aeotec_zw096_smart_switch_6_energy:
  friendly_name: 'Bedroom Fan Energy'
sensor.aeotec_zw096_smart_switch_6_power:
  friendly_name: 'Bedroom Fan Power'
  hidden: true
sensor.aeotec_zw096_smart_switch_6_voltage:
  friendly_name: 'Bedroom Fan Voltage'
  hidden: true
sensor.aeotec_zw096_smart_switch_6_previous_reading:
  hidden: true
sensor.yr_symbol:
  friendly_name: 'Weather'
sensor.yr_temperature:
  friendly_name: 'Temp'
sensor.ecolink_door_access_control:
  hidden: true
sensor.ecolink_door_alarm_level:
  hidden: true
sensor.ecolink_door_alarm_type:
  hidden: true
sensor.ecolink_door_burglar:
  hidden: true
sensor.ecolink_door_power_management:
  hidden: true
sensor.ecolink_door_sourcenodeid:
  hidden: true
sensor.kitchen_multisensor_relative_humidity:
  friendly_name: 'Kitchen Humidity'
sensor.kitchen_multisensor_temperature:
  friendly_name: 'Kitchen Temp'
sensor.kitchen_multisensor_ultraviolet:
  hidden: true
sensor.kitchen_multisensor_sourcenodeid:
  hidden: true
sensor.kitchen_multisensor_luminance:
  hidden: true
sensor.kitchen_multisensor_alarm_level:
  hidden: true
sensor.kitchen_multisensor_alarm_type:
  hidden: true
sensor.kitchen_multisensor_burglar:
  hidden: true
sensor.fibaro_system_fgrgbwm441_rgbw_controller_exporting_10_32:
  hidden: true
sensor.fibaro_system_fgrgbwm441_rgbw_controller_power_10_4:
  friendly_name: 'Kitchen LED Power'
sensor.fibaro_system_fgrgbwm441_rgbw_controller_power_10_8:
  hidden: true
# Car
sensor.c71e5d401fbf11e795090050568f5b13_fuel:
  friendly_name: 'Fuel Level'
  icon: mdi:fuel
sensor.c71e5d401fbf11e795090050568f5b13_odometer:
  friendly_name: 'Odometer'
  icon: mdi:gauge
sensor.c71e5d401fbf11e795090050568f5b13_range:
  friendly_name: 'Driving Range'
  icon: mdi:road-variant
  hidden: true
  hidden: true
So actually you want to customize the entity_id that already exists, Sorry for my misunderstood, I thought you are using in sensor platform.
customize: !include_dir_list customize/
in sensors.yaml file, you need 2 space before like I past below
    hidden: true
when you put directly under customize:
customize:
    hidden: true
Thanks, I tried that suggestion and it gives me a configuration error:
2018-01-24 00:55:09 ERROR (MainThread) [homeassistant.config] Invalid config
for [homeassistant]: expected a dictionary for dictionary value @ data['customize']. Got
[OrderedDict([('sensor.aeotec_zw096_smart_switch_6_current', OrderedDict([(
'friendly_name', 'Bedroom Fan Current'), ('hidden', True)])), ('sensor.aeotec_zw096_smart_switch_6_energy',
OrderedDict([('friendly_name', 'Bedroom Fan Energy')])),
('sensor.aeotec_zw096_smart_switch_6_power',
OrderedDict([('friendly_name', 'Bedroom Fan Power'), ('hidden', True)])),
('sensor.aeotec_zw096_smart_switch_6_voltage', OrderedDict([('friendly_name',
'Bedroom Fan Voltage'), ('hidden', True)])), ('sensor.aeotec....
(See /home/homeassistant/.homeassistant/configuration.yaml, line 1)
Maybe it will help if I upload my config to github.
Here is my sensors file: https://github.com/nemec/home-assistant-config/blob/master/customize/sensors.yaml
And my main configuration: https://github.com/nemec/home-assistant-config/blob/master/configuration.yaml#L9
have you try !include_dir_merge_list
customzie: !include_dir_merge_list customize/
This mean every yaml file in customize folder has to be be under customize platform
What would that look like? The customize entry in the documentation doesn’t include any list at all: Customizing entities - Home Assistant
And the docs also mention:
It is important to note that when using !include_dir_merge_list, you must include a list in each file
