I am a 78 year old man who, seven months ago, started experimenting with Home Assistant. I installed several sensors for temperature, humidity, air quality, some relays, light bulbs, etc. With the help of the forum, I learned the basic configuration of H.A. and even did some simple automations, in addition to using Lovelace.
Now I want to move towards a less amateur installation in my small apartment. I bought a Philips Hue plafond (I’m waiting for the bridge) and installed a Netatmo weather station.
I decided to do a new “clean” installation of the latest version of Home Assistant (0.94.3), and then add the new components.
My first problem appears when I try to customize some entities, something I did without difficulties in my “old” installation. I have tried several procedures without success. Under the “Configuration menu” > “Customization”. From the frontend (dev-states menu) and also manually modifying the files configuration.yalm and customoze.yalm.
Unfortunately, I can’t completely customize the entities. In some cases I can customize the friendly-name, but not the icon and in others nothing.
This is the message that appears and these are my configuration files.
Este es mi archivo configuration.yalm
########## PERSONALIZACION ###########################################
# Consultar el archivo customize.yalm.
customize: !include customize.yaml
Este es mi archivo customize.yalm
sensor.waqi_sangroniz_sondika_pais_vasco_spain:
friendly_name: WAQI Sangroniz
icon: mdi:biohazard
sensor.netatmo_dormitorio_co2:
friendly_name: Dormitorio
icon: mdi:periodic-table-co2
sensor.date:
friendly_name: Fecha
icon: mdi:calendar-month
sensor.time:
friendly_name: Hora
icon: mdi:clock-outline
sensor.moon:
friendly_name: Luna
sensor.sun:
friendly_name: Sol
sun.sun:
friendly_name: Sol
sensor.dark_sky_apparent_temperature:
friendly_name: Sensación térmica
icon: mdi:thermometer-lines
Can someone help me?
Thanks in advance.
