I have the following config:
configuration.yaml:
homeassistant:
# Load packages
packages: !include_dir_named integrations
In integrations/homeassistant.yaml:
homeassistant:
# Lets me customize individual entities
customize: !include_dir_merge_named ../customizations/entities
# Lets me custimize all entities in a domain
customize_domain: !include_dir_merge_named ../customizations/domains
If I now add the following two settings to my integrations/homeassistant.yaml the customizations are not loaded and applied:
homeassistant:
# Enable Multi-factor Authentication (MFA)
auth_mfa_modules:
- type: totp
# Trusted Networks
auth_providers:
- type: trusted_networks
trusted_networks:
- xxx.xxx.xx.xxx/24
If I remove the auth_mfa_modules and auth_providers settings from the yaml file, the customizations works fine!
Any idea what’s the problem?
Thanks and regards,
Daniel.
