Customize only reading first entity
Hi All
My customize is only working for the first entity in my yaml file, has anyone else had this issue?
my yaml file:
switch.garden_lights:
  icon: mdi:lightbulb
  friendly_name: The Lights
automation.boil_kettle:
  icon: mdi:kettle
  friendly_name: The Kettle
switch.garden_water_1:
  icon: mdi:water
switch.garden_water_2:
  icon: mdi:water
you should post your whole config that contains the pointer to this file
so I have narrowed it down a little, its working it just seems you can’t customize an automation. Is that correct? Should the following work;
You should be able to. Are you sure you have the correct entity_id?
so I checked and you are right I had the wron g entity, so I swapped it to this and it still didn’t work;
input_boolean.boil_kettle
what about this part
so I have this in customize;
input_boolean.boil_kettle:
  icon: mdi:lightbulb
and that is the correct entity as I can see it in my groups yaml.
it still wont set the icon correctly.
You should set the input_boolean’s icon in the same place you create it:
input_boolean:
  boil_kettle:
    icon: mdi:lightbulb
