Customizing Lovelace Dashboard per User – Is It Possible?
Hey everyone,
I’ve been tinkering with my Home Assistant setup and trying to figure out if there’s a way to customize the Lovelace dashboard for different users. Ideally, I want to show different views or cards based on who’s logged in. For example:
  • Show some advanced controls only when I’m logged in
  • Display a simplified view for my parents when they access the dashboard
  • Maybe even hide certain devices entirely from some users
I’ve looked into user-based dashboards a bit but still not fully sure if this is possible natively or if I need to use some workarounds (like custom cards or YAML tricks). I’m currently using mostly the UI editor but I don’t mind diving into YAML if needed.
Has anyone done something similar?
Would love to hear how others are managing user-specific UI or if there’s a best practice for this kind of setup.
Thanks in advance!
If you’re using Sections layout you can specify which users can see each view. Within a view you can specify which users can see a section. And similarly within a section you can specify which users can see a card - although not all custom cards support this without nesting it inside another card that does. In each case there are options under “Visibility”. I have a couple of views that are only presented to me, not other users.
If I’m not mistaken, the default Lovelace interface has had the ability to restrict access to individual views by user for a number of years now. The ability to similarly restrict cards is relatively new, though.
Thanks for guidance!
