I am new to ESPHOME. I use a ESP32 with a climate PID. Output is a DAC32. I want to deactivate the heat/DAC32 output GPIO25. This shall be not 0V but high impedance.
I tried to the pin to input using below lambda but this does not seem to work. It still behaves like 0V
Any guidance would be highly appreciated.
pinMode(25, INPUT);
I know, a bit late, but…
Your code works when switching a GPIO between digital In and out. Maybe the DAC output works differently. I don’t know how to set the “pinMode” for analog pins…
I have used this code with a “select” component, to switch 2 GPIO pins back and forth between output low, and high impedance input:
select:
name: Range Ch 1
options:
#- "Auto"
- "2,5V"
- "16V"
- "100V"
initial_option: "16V"
optimistic: true
on_value:
then:
lambda: |-
if(i==0) {
pinMode(6, INPUT);
pinMode(7, INPUT);
if(i==1) {
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
pinMode(7, INPUT);
if(i==2) {
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
pinMode(6, INPUT);
Works on a ESP32-C3.
