I flashed my Neos Smartcam with success. I can confirm I have access to the Web UI, SSH, and I can see the camera with its stream in Home Assistant, using the Generic IP Camera integration.
I want to be able to get all the sensors and actions in HA, as illustrated in the HA guide on the Dafang repo.
I have other Zigbee devices (switches) detected through the MQTT moquitto broker and Zigbee2MQTT. This is 100% working.
My switches were detected after I permitted devices in Zigbee2MQTT. But I can’t find a way to trigger discovery / pairing for the camera.
I can’t find the camera and all its sensors. I would like to use it to create automation on motion detection, etc.
- I modified the dafang config to connect to my local HA server, homeassistant.local. I also tried core-mosquitto, as it’s used by Zigbee2MQTT
- I restarted the dafang camera, got it off and on again, restarted services
- I restarted HA, checked the config, user access
There’s no trace of connection, successful or not, in the logs.
Any idea?
