Hi guys,
I have the same problem. Im using Hass.io with the Mosquitto Broker Add-on. I have the Dafang hack working an i can reach and use the RTSP stream.
I edited /system/sdcard/config/mqtt.conf
And put in my information:
# Options for mosquitto_sub & mosquitto_pub
USER=USER1234
PASS=PW1234
HOST=192.168.1.125
PORT=1883
# Define a location
LOCATION="myhome"
# Define device name
DEVICE_NAME="dafang_cam_1"
# Define the base topic used by the camera
# send a message to myhome/dafang/set with the payload help for help.
# Results will be placed in myhome/dafang/${command} or topic/dafang/error - so please subscribe topic/d
TOPIC="$LOCATION/$DEVICE_NAME"
When i look in the Add-on logs i see the following:
1580413963: Client mosqpub|7223-DAFANG_CAM disconnected.
1580413963: New connection from 192.168.1.181 on port 1883.
1580413963: New client connected from 192.168.1.181 as mosqpub|7228-DAFANG_CAM (p1, c1, k60, u'Mosquitto').
1580413963: Client mosqpub|7228-DAFANG_CAM disconnected.
1580413964: New connection from 192.168.1.181 on port 1883.
1580413964: New client connected from 192.168.1.181 as mosqpub|7236-DAFANG_CAM (p1, c1, k60, u'Mosquitto').
1580413964: Client mosqpub|7236-DAFANG_CAM disconnected.
1580413964: New client connected from 192.168.1.181 as mosqpub|7244-DAFANG_CAM (p1, c1, k60, u'Mosquitto').
1580413964: Client mosqpub|7244-DAFANG_CAM disconnected.
1580413965: New connection from 192.168.1.181 on port 1883.
1580413965: New client connected from 192.168.1.181 as mosqpub|7276-DAFANG_CAM (p1, c1, k60, u'Mosquitto').
1580413965: Client mosqpub|7276-DAFANG_CAM disconnected.
Mosquitto add-on config:
"logins": [
"username": "USER1234",
"password": "PW1234"
"anonymous": true,
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"require_certificate": false,
"quiet_logs": true
I got one time discovery of the MQTT entities but now there not updating anymore or reacting to input. I restarted HA and the camera, and tried to stop/start the MQTT services on the camera but no succes.
Any help?
