Dahua NVR motion detection trigger
Has anyone successfully integrated Dahua NVR motion detection as a HA trigger?
Thank you
Hi, how have you integrated your NVR in HA?
Hi, not integrated yet. I tried using Motioneye to get motion detect and trigger but had no luck with that.
Dahua and Amcrest are same. Try Amcrest integration
Simply integrate the NVR via HA Onvif integration and all detection types that your NVR offers (motion, IVS, … ) are available as triggers under HA.
However, there is a bug with Core 2025.4.x with the naming of individual sensors. This means that the sensors only appear under the device name in the device overview. See:
You could probably also integrate the NVR using rroller’s Dahua integration, but rroller is no longer actively maintaining or developing this. Furthermore, with my Dahua NVR, the rroller Dahua integration floods the NVR with log entries every second. I can’t tell you why that’s the case, and rroller hasn’t commented on it either.
