I have recently bought a daikin ac unit with the wifi controller and I integrated it in HA. I can turn it on and off etc. What I cannot seem to be able to do is to check if the AC changed states with an automation.
I want to be able to automatically turn it off after 1 hour and I was thinking to have an automation that checks if the state has changed from off and the start a delay timer for 1 hour and then turn the AC off.
However, this doesn’t seem to happen. Here is the automation that I currently have:
alias: AC off
description: ''
- platform: state
entity_id: climate.birou
attribute: hvac_modes
condition: []
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
- service: climate.set_hvac_mode
hvac_mode: 'off'
mode: single
The action part works because I checked. What doesn’t work is the trigger part.
yes I can imagine that will not work. to be honest we use the unit for cooling only and we tend to forget it running for too long. so I wanted a way to turn it off automatically. 1 hour is more than enough to get to a nice temperature here!
