Daikin Altherma + Modbus TCP
I'm trying to monitor my Daikin Altherma heat pump through its built-in Modbus TCP interface (port 502).
Important: I'm not trying to control or modify any settings. My goal is only to read data for energy analysis and diagnostics (COP estimation, compressor behaviour, power consumption, possible cycling/defrost events, etc.).
What I've found so far:
  • Modbus TCP enabled and reachable on port 502
  • Slave ID = 3
  • Register 30775 returns a live value that changes every second
  • Reading register 30775 as a 32-bit value gives values around 700–3000, which looks very much like instantaneous thermal or electrical power
  • Many nearby registers return 4294967295 or Modbus exception responses
  • Read Device Information does not seem to be supported
Example Python test:
r = client.read_input_registers(    address=30775,    count=2,    slave=3)value = (r.registers[0] << 16) + r.registers[1]print(value)
Questions:
  1. Does anyone have a register map for Daikin Altherma Modbus TCP?
  2. Is register 30775 documented somewhere?
  3. Are there registers available for:
  • electrical consumption,
  • compressor frequency,
  • leaving water temperature,
  • return water temperature,
  • DHW temperature,
  • COP / energy counters?
  1. Has anyone successfully integrated these registers into Home Assistant for monitoring purposes?
Any documentation, register lists, or experience would be greatly appreciated.
Thanks!
Have you tried the Protocol Wizard to help in your experiments?
