I am trying to integrate two Daikin air conditioning units with Home Assistant using the Daikin Onecta integration.
Home Assistant version:
- Installation Method: Home Assistant OS
- Core: 2026.6.3
- Supervisor: 2026.06.1
- Operating System: 17.3
- Frontend: 20260527.5
Air conditioning units:
Model: ATXP25N5V1B9
Serial Number: T003657
Model: ATXP25N5V1B9
Serial Number: T003725
Both units work correctly through the Onecta mobile application.
When I try to add the Daikin Onecta integration, the OAuth login page returns:
Error code: unauthorized_client
Error details: The client was not found.
The integration cannot be completed and no devices are discovered.
Has anyone experienced this issue recently or knows if there is a problem with the Daikin Onecta OAuth configuration?
Thank you very much for any help.
