DALI to Home Assistant
I am looking for a solution to integrate DALI lights to Home Assistant. Apparently there is for example these ADFweb DALI adapters, which is one option. Is there any other feasible solutions? I have not yet decided my multi-master so I have still room for adjustment in my plan. Does some of the multi-masters / gateways also enable connection to HA? How have you guys done it? Any suggestions?
My thinking at the moment is to use MeanWell controllers and B.E.G Luxomat PIR sensors.
I was already using KNX at home, so I purchased a KNX Dali Gateway. I control my KNX through Home Assistant. It is working very well.
So in that case you have this DALI KNX gateway, that also works as a multi-master for your DALI products, right? Which components you need to have on KNX side then to connect to HA?
A Knx IP interface, a KNX power supply and an ETS license (maybe Demo is enough - depends on the Dali gateway).
There is the Atios Knx Bridge that would have a Dali Gateway and Knx IP interface in a single device. Don’t know it it supports multimaster or if it works without any Knx TP hardware (but I would think so).
On the other hand there is a Lunatone Dali Interface with an HTTP api (or Nodered plugin) that could be used to create a HA integration.
