Dallas sensor filters not working in HA
This is my first setup in HA. I just installed a Wemo D1 with ESPHome and a dallas temp sensor.
Everything works well and I can see the temperatur reading in HA in Celcius.
However, I would like to show in in F instead and trying to use the filters/lambda to do so. Here’s the yaml below:
When doing this, I still only see the temp in C.
I know the conversion works with the filters/lamda (using the logs), but somehow HA doesn’t pick it up.
Any clue, do I need to setup something else in HA?
Thanks!
