i just received and installed my Danalock V3 and am not too sure if I should like it or not. The app is quite minimal and buggy so I was hoping that it’s nicely integrated in HA.
The basics of locking and unlocking work from within HA but the big issue is that I can’t figure out how to differentiate between unlocking and opening the door.
Unlocking: Rotate the lock to the set open position. (desired for automated unlocking the door in the morning)
Open: Rotate further so the latch opens and the door can be pushed open. (only a fixed handle outside, so required to get in or let guests in)
If I I set the hold and open value to >1 unlocking the door leads to opening the door. If I set it to 0 it leads to only unlocking the door but also takes away the possibility to “hold and open” the door from within the Danalock app.
How do you deal with this?
Thank you
