Danfoss Ally thermostat: firmware archive [v1.28, v1.20, v1.18, v1.08] & specifications [zha] [deconz] [zigbee2mqtt]
Next Deconz version will have it too
Great. Do you have a link? cant find.
2.10.0-beta https://github.com/dresden-elektronik/deconz-rest-plugin/pull/4408
Looks like great features.
I have tried to upload the firmware through file editor, and added the ZHA OTA code to my config file, but where do I go from here to make the update happen?
You are unable to set HVAC mode on these.
Check the Danfoss Ally Radiator Thermostat 1.12 Zigbee Cluster Specifications 09042021.pdf from the danfoss website.
0x04: Heating control active
Everything else rejected with INVALID_VALUE
For those updating from deCONZ
  1. Open OTAU plugin
  2. Select device
  3. Select OTAU file you got from Danfoss Ally™ support | Danfoss
  4. Click update
  5. Wait for some hours, mine took 2+h to update per device
after reading this thread I exchanged all of my Homematic IP thermostats with the Danfoss Allys hoping for a smooth, zigbee-only smarthome experience.
Sadly, everything BUT the thermostats are working reliably.
Most of the time, settings I do from Home Assistant (with zha) don’t reflect on the devices. And I mean the most trivial things like just setting the temperature via build-in lovelace cards, scripts etc.
Since I am not sure which firmware version is running on the Allys, I would like to check that but don’t know how.
Can anyone give me a hint?
Right now, I don’t have deconz running, only HA with zha.
I am only guessing here, but I am running 1.08 and my device shows this information underneath Firmware:
So when 1.12 is released and I have updated them through OTA, I will assume it will show (…)112 in the end.
To your other points, it sounds weird to me, as I have 5 devices that work reliably.
For instance if I change the set target temperature through a lovelace card, it will update the displayed value on the screen around 10-15 seconds later.
Only point of critique, which I guess is general to all TRVs, is that temperature readings are showing too high a temperature as they measure right next to the radiator.
And this I have solved by making it adhere to external zigbee thermal readers.
Thank you!
Then I was looking at the correct spot.
In the firmware field i see 10c (which is odd since 10c in hexadecimal comes after 108, right?)
Regarding the update process, I followed the steps in the second post, placed the .ota in the correct directory and added that in the config but obviously the update process hasn’t started during the last two weeks.
Is there anything I can do manually to kickstart the update (using CC2652P+zha+HA) or should I just temporarily use my linux notebook with deconz and conbee II ?
It’s been a while since I updated it, but I actually have two files present in the OTA directory.
The files are identical, but naming is different. As far as I remember, it only would automatically update with one of them, but which one I don’t know.
So my suggestion is for you to duplicate the file and have the naming be as follows:
1246-0100-01080108.0002.ota
1246-0100-01080108.0002_(DF4ECCE1).ota
This allowed the devices to automatically update. Which they did within a few hours (perhaps you could restart the devices and your HA instance, to push things along).
I think there is a way to request them to update, but as I didn’t have any issues. I have not investigated this.
It could also be some kind of compatibility issue between the TRVs, the CC2652P stick I am using and the zha-zigpy implementation.
If no one here has exactly this combination in place I would make a test run with the conbee instead of my current stick.
That is not unthinkable! I use the Conbee II myself.
Just to chime in, I just set up the Danfoss Ally TRVs with ZHA and a Conbee II last week. I was previously using Danfoss’s bridge and app, so I know I’ve got firmware 1.08. At first, I had a 5-15 minute delay between setting the temperature via the Lovelace card and the TRV actually adjusting. Perhaps a coincidence, but after applying the latest HA update (now at 10.3), it seems the TRVs now respond within a few seconds. So maybe the latest HA update solves some of your issues @massaquah?
My only mystery is that the TRVs often continue report they are still “heating” when I set the temperature much lower than the current measured temperature. Sometimes it switches to “Idle” after several hours, sometimes not. The radiators are indeed completely cold to the touch in this situation, and the display on the units themselves show the temperature I’ve set via Lovelace, so not sure the incorrect status has any consequence.
I followed your 4-step-guide with deconz but noticed something odd in the debug log:
OTAU_NO_IMAGE_AVAILABLE
Did you see that as well?
I just hit the “query” button again and according to the debug log it seems that the update was performed.
But the log says fw version is 10C??
After re-pairing the just “updated” device to HA it still reads firmware 10c:
Just a thought – C in hex means 12… so maybe you somehow already have firmware version 1.12?? Indeed, this tech sheet gives an example where a (hypothetical) version 1.13 would be coded 10D – search for firmware:
https://assets.danfoss.com/documents/176987/AM375549618098en-000101.pdf
Interesting thought.
But I downloaded the file from the page linked in the first post.
And I just had a look at the binary ota file with a text editor and saw this in clear text in the first line:
06-10-2020 V.0108.0108
Right, but if your Ally TRVs somehow came with 1.12 factory pre-installed, then I would guess that the OTA update mechanism wouldn’t try to downgrade it to 1.08.
That would make sense!
I hope that 1.12 won’t provide the issues that @massaquah is experiencing.
