Hello folks,
I have a very specific problem in that I cannot seem to include either of the two new RXZ-2C dual-channel z-wave receivers I have purchased.
Despite some obstacles (with respect to instructions/missing information) getting the RXZ-2C factory reset, which is a pre-cursor to putting it into inclusion mode in the first instance, I am now at a stage where when I try an Add Node in the HA GUI via Z-Wave Network Management, the node_add fails.
For anyone interested in how to get this thing factory reset (PROG LED slow green flashing), the sequence is as follows:
(I figured it out by following an openHAB thread (openHAB thread) on the same subject of inclusion to Chris’ Z-Wave device DB here: Chris Jackson’s openHAB stuff)
- Place in Program Mode (press PROG so the LED is on steady RED)
- Hold CH1 for >=15 seconds (Prog LED flashes red/green)
- Press PROG for >=15 seconds (CH1/CH2 show steady RED and PROG LED slow flashes green)
At this point, I can then put the receiver into inclusion/pairing mode by pressing PROG to make it solid red and subsequently pressing and holding PROG and CH1 for >=3 seconds which starts some slow red flashing of the PROG LED.
Can anyone help me with this?
These are the details surrounding my configuration:
I am running HA 105.5 (supervisor 209) in docker on Ubuntu 18.04.3.
The only addons I run from within HA so-to-speak are:
- Check Home Assistant configuration
- Samba share
I have an Everspring SA413 USB stick (plugged in to a long USB extension lead - not the back of the server tin!) which is reported as a “Z-Wave (Sigma Designs) UZB Z-Wave USB Adapter” in HA.
I do NOT have ModemManager!!! (previosuly removed with an apt-get purge)
I am running open-zwave 1.6 which I have git-pulled into a subdirectory of my config and my configuration.yaml includes the following lines for my z-wave config:
# z-wave component
zwave:
usb_path: /dev/serial/by-id/usb-0658_0200-if00
network_key: !secret zwave_network_key
config_path: /config/openzwave_config
I have 16 x Eurotronic Spirit Z-Wave TRVs, all of which have been tickety-boo for over a year. They have just worked for me. They are all Z-Wave plus devices and are all included “secure”.
I have 4 x Aeotec Z-Wave repeaters dotted about the house to build my mesh.
I have turned on debug logging for homeassistant.components.zwave but get two lines when I try and add (then subsequently remove) the node:
2020-03-07 13:49:25 INFO (SyncWorker_0) [homeassistant.components.zwave] Z-Wave add_node have been initialized
2020-03-07 13:50:11 INFO (SyncWorker_3) [homeassistant.components.zwave] Z-Wave remove_node have been initialized
This is an extract from my OZW_Log.txt:
2020-03-07 13:49:25.293 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-03-07 13:49:25.293 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-03-07 13:49:25.293 Detail, Node001, Expected callbackId was received
2020-03-07 13:49:25.293 Detail, Node001, Expected reply was received
2020-03-07 13:49:25.293 Detail, Node001, Message transaction complete
2020-03-07 13:49:25.293 Detail, contrlr, Removing current message
2020-03-07 13:49:25.293 Detail, Notification: ControllerCommand - Waiting
2020-03-07 13:49:25.294 Info, WriteNextMsg Controller nothing to do
2020-03-07 13:49:32.239 Detail, Received: 0x01, 0x16, 0x00, 0x4a, 0xdf, 0x02, 0x1d, 0x0f, 0x02, 0x10, 0x00, 0x25, 0x60, 0x91, 0x72, 0x8f, 0x86, 0x43, 0xef, 0x8f, 0x85, 0x8e, 0x84, 0x7d
2020-03-07 13:49:32.239 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-03-07 13:49:32.239 Info, ADD_NODE_STATUS_NODE_FOUND
2020-03-07 13:49:32.239 Detail, Notification: ControllerCommand - InProgress
2020-03-07 13:49:32.242 Detail, Received: 0x01, 0x16, 0x00, 0x4a, 0xdf, 0x04, 0x1d, 0x0f, 0x02, 0x10, 0x00, 0x25, 0x60, 0x91, 0x72, 0x8f, 0x86, 0x43, 0xef, 0x8f, 0x85, 0x8e, 0x84, 0x7b
2020-03-07 13:49:32.242 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-03-07 13:49:32.242 Info, ADD_NODE_STATUS_ADDING_CONTROLLER
2020-03-07 13:49:32.242 Info, Adding controller ID 29
2020-03-07 13:49:32.242 Detail, Notification: ControllerCommand - InProgress
2020-03-07 13:49:54.111 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0xdf, 0x07, 0x1d, 0x00, 0x77
2020-03-07 13:49:54.111 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-03-07 13:49:54.111 Info, ADD_NODE_STATUS_FAILED
2020-03-07 13:49:54.111 Detail, Removing current message
2020-03-07 13:49:54.111 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-03-07 13:49:54.111 Detail, Notification: ControllerCommand - Failed
2020-03-07 13:49:54.113 Detail,
2020-03-07 13:49:54.113 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-03-07 13:49:54.166 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0xdf, 0x06, 0x00, 0x00, 0x6b
2020-03-07 13:49:54.166 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-03-07 13:49:54.166 Detail, Node006, Expected reply was received
2020-03-07 13:49:54.166 Detail, Node006, Message transaction complete
2020-03-07 13:49:54.166 Detail, contrlr, Removing current message
2020-03-07 13:49:54.166 Detail, Notification: ControllerCommand - Completed
2020-03-07 13:50:11.696 Detail, Queuing (Controller) Remove Device
2020-03-07 13:50:11.697 Info, Remove Device
2020-03-07 13:50:11.697 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0xe0, 0xd0
2020-03-07 13:50:11.697 Detail, Notification: ControllerCommand - Starting
2020-03-07 13:50:11.698 Detail,
2020-03-07 13:50:11.698 Info, contrlr, Sending (Command) message (Callback ID=0xe0, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0xe0, 0xd0
2020-03-07 13:50:11.703 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0xe0, 0x01, 0x00, 0x00, 0x52
2020-03-07 13:50:11.704 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-03-07 13:50:11.704 Info, REMOVE_NODE_STATUS_LEARN_READY
2020-03-07 13:50:11.704 Detail, Node001, Expected callbackId was received
2020-03-07 13:50:11.704 Detail, Node001, Expected reply was received
2020-03-07 13:50:11.704 Detail, Node001, Message transaction complete
2020-03-07 13:50:11.704 Detail, contrlr, Removing current message
2020-03-07 13:50:11.704 Detail, Notification: ControllerCommand - Waiting
2020-03-07 13:50:11.705 Info, WriteNextMsg Controller nothing to do
2020-03-07 13:50:18.587 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0xe0, 0x02, 0x00, 0x00, 0x51
2020-03-07 13:50:18.587 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-03-07 13:50:18.587 Info, REMOVE_NODE_STATUS_NODE_FOUND
2020-03-07 13:50:18.587 Detail, Notification: ControllerCommand - InProgress
2020-03-07 13:50:18.798 Detail, Received: 0x01, 0x16, 0x00, 0x4b, 0xe0, 0x04, 0x1d, 0x0f, 0x02, 0x10, 0x00, 0x25, 0x60, 0x91, 0x72, 0x8f, 0x86, 0x43, 0xef, 0x8f, 0x85, 0x8e, 0x84, 0x45
2020-03-07 13:50:18.798 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-03-07 13:50:18.798 Info, REMOVE_NODE_STATUS_REMOVING_CONTROLLER
2020-03-07 13:50:18.798 Info, Removing controller ID 29
2020-03-07 13:50:18.798 Detail, Notification: ControllerCommand - InProgress
2020-03-07 13:50:18.801 Detail, Received: 0x01, 0x16, 0x00, 0x4b, 0xe0, 0x06, 0x1d, 0x0f, 0x02, 0x10, 0x00, 0x25, 0x60, 0x91, 0x72, 0x8f, 0x86, 0x43, 0xef, 0x8f, 0x85, 0x8e, 0x84, 0x47
2020-03-07 13:50:18.801 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-03-07 13:50:18.801 Info, REMOVE_NODE_STATUS_DONE
2020-03-07 13:50:18.801 Detail, Notification: ControllerCommand - Completed
2020-03-07 13:50:18.802 Detail, Node029, Notification: NodeRemoved
2020-03-07 13:50:18.898 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0xe0, 0x06, 0x00, 0x00, 0x55
It should be noted that I only press the Add Node button in HA once. I also only press the Remove Node button in HA once.
I can supply my redacted configuration.yaml, full home-assistant.log and full OZW_Log.txt if requested.
TIA,
bikefright
