Dashboard 3.0
Hi all,
I’m building a lightweight web app that helps you create Home Assistant dashboards faster and easier.
The goal is simple. Less YAML. Less configuration. Just click, add and drag.
What you can do:
  • Connect with your Home Assistant instance using the API token
  • Automatically load your entities
  • Add cards for light, climate, media_player and more
  • Drag and drop cards anywhere on the canvas
  • Freely resize and rearrange your layout
  • Switch between day and night mode
  • Run everything in Docker, so you can host it locally or on your server
Typical flow:
  • Start the app
  • Enter your API key
  • Select your entities
  • Drag cards onto the dashboard
  • Done, your dashboard works immediately
Focus:
  • Fast setup
  • Clean and simple UI
  • No technical knowledge required
  • Works great on tablets, wall displays and desktops
When it’s ready, I will publish everything on GitHub.
This will take a few more weeks.
I’d really like feedback from the community:
  • Which cards are you missing today
  • What slows you down when building Lovelace dashboards
  • Which features should I prioritize
Update on the dashboard.
Roomcard
The roomcard had an update. The new functionalities are
  • Set icoon for card
  • Set mediaplayer and light entity
  • Open modal the set of the lights in the room
Image card
Upload your image and place it on your dashboard. With or without background/border
Screensaver
Enable screensaver in the configuration and choose your weather entity and integratie with Team Tracker to show your favorite club. Also connect to Pexels (API) to generate the images
Pill cards
Add pill cards to your dashboard and set conditions to change the card color based on the entity status.
Added Music Assistant Support.
Take a look on the youtube video for more information
Music Assistant Integration
