Dashboard Arrangement
Sorry to be a doofus here, but this stuff really hurts my head.
I want to build this Dashboard:
I know how to do the bits and pieces. Date, weather, sliders, etc.
I don’t have the slightest notion how to go about arranging them as seen in the image.
Any guidance you could provide would be greatly appreciated.
Can you clarify what you’re actually seeing, so that your goal is clearer? I can’t really tell which part of the screenshot you posted I should focus on to try to suggest something.
What I posted is a graphic I built in PowerPoint.
It’s what I’m trying to assemble out of about 6 bits and pieces making up the display.
thanks
Okay,
I’ve put all the pits and pieces in a dashboard:
Goals:
  1. All the backgrounds to be uniform color.
  2. The date/time in the upper left corner
  3. The weather in the upper right corner, in a narrower width
  4. The sliders underneath the top row, in the center
I’ve looked at vertical stacks, horizontal stacks to no avail
cheers
Another pathetic attempt
I used a Vertical Stack card with two Horizontal Stack cards, with the Date/Weather in the upper Horizontal, and the Sliders and On/Off button (a Vertical stack) in the bottom Horizontal.
Have no earthly idea why:
  1. It’s all jammed together
  2. Why there is a line between the left slider and the on/off button. The setup here is the same as the other two, just different entities
  3. Why the Icons on the Bed and Utility room On/Off button is a different color. Again, the exact same code.
Here is the yaml if it helps:
  - title: Home
    sections:
      - type: grid
        cards:
          - type: heading
            heading: Media
          - type: vertical-stack
            cards:
              - type: horizontal-stack
                cards:
                  - type: custom:digital-clock
                    dateFormat:
                      weekday: long
                      day: 2-digit
                      month: short
                    timeFormat:
                      hour: 2-digit
                      minute: 2-digit
                  - show_current: true
                    show_forecast: false
                    type: weather-forecast
                    entity: weather.forecast_home
                    forecast_type: daily
                    forecast_slots: 1
            cards:
                cards:
                  - type: custom:vertical-stack-in-card
                    cards:
                      - type: custom:custom-mixer-card
                        faderWidth: 200px
                        faderHeight: 400px
                        borderRadius: 24px
                        faderThumbColor: '#DDD'
                        faderTrackColor: '#DDD'
                        faderActiveColor: '#22ba00'
                        faderInactiveColor: '#F00'
                        faderTheme: modern
                        faders:
                          - entity_id: number.tsr_700_main_volume_db
                      - type: custom:button-card
                        show_name: false
                        show_icon: true
                        tap_action:
                          action: toggle
                        entity: remote.bravia
                        icon: mdi:power
                        state:
                          - value: 'on'
                            icon: mdi:power
                            color: green
                          - value: 'off'
                            icon: mdi:power
                            color: red
                    cards:
                        cards:
                            faderWidth: 200px
                            faderHeight: 400px
                            borderRadius: 24px
                            faderTheme: modern
                            faders:
                              - entity_id: number.tsr_700_zones_volume_db_2
                            show_name: false
                            show_icon: true
                            tap_action:
                              action: toggle
                            entity: media_player.tsr_700_zones_2
                            icon: mdi:power
                            state:
                              - value: 'on'
                                icon: mdi:power
                                color: green
                              - value: 'off'
                                icon: mdi:power
                                color: red
                    grid_options:
                      columns: 6
                      rows: 1
                    cards:
                        cards:
                            faderWidth: 200px
                            faderHeight: 400px
                            borderRadius: 24px
                            faderTheme: modern
                            faders:
                              - entity_id: number.tsr_700_zones_zone2_volume_db_2
                            show_name: false
                            show_icon: true
                            tap_action:
                              action: toggle
                            entity: media_player.tsr_700_zones_zone2_2
                            icon: mdi:power
                            state:
                              - value: 'on'
                                icon: mdi:power
                                color: green
                              - value: 'off'
                                icon: mdi:power
                                color: red
                    grid_options:
                      columns: 6
                      rows: 1
                grid_options:
                  columns: 6
                  rows: 1
        column_span: 1
Cheers
Are you using the dashboard type Panel?
Test this code out in a new dashboard that is setup as a panel. I also increased the font-size.
type: panel
path: ""
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 1fr 1fr 1fr
      margin: 0px 0px 0px 0px
    cards:
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderThumbColor: "#DDD"
            faderTrackColor: "#DDD"
            faderActiveColor: "#22ba00"
            faderInactiveColor: "#F00"
            faderTheme: modern
            faders:
              - entity_id: number.left_firmness
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                font-size: 30px !important;}
                .fader-value {
                font-size: 25px !important;}
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderTheme: modern
            faders:
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                .fader-value {
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderTheme: modern
            faders:
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                .fader-value {
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
title: Example
Thank you for your amazing work.
My installation of HA must be buggered up or something as my output looks nothing like yours.
I Created a new Dashboard, and set it to panel. I pasted your yaml verbatim. I changed the controls to be the ones for my TV and AVR’s.
The columns with the slider and button are not lined up, the text is no different in size, and changes to the size in the yaml makes no difference. And, the icons are different colors.
To make matters even worse, the display is completely different on my tablet than my computer screen.
Computer:
Tablet:
I’ve tried both sets of slider cards referenced in this thread with the same result.
I’ve about to the point of crying uncle. This should simply not be this difficult.
What version of card mod do you have installed?
From HACS:
That’s part of your issue. Please install v3.4.4, v3.5 was recalled.
It may beneficial to change the dashboard to Sections that is one card wide if you are using across multiple devices with different screen sizes.
Ok,
Reloaded card-mod.
Helped a bit.
This Dashboards will br displayed only on two identical tablets.
This is a start.
Let me futz around with it.
Thanks for all your help.
Here is a Sections example
type: grid
cards:
  - type: heading
    heading: New section
    heading_style: title
    grid_options:
      columns: full
      rows: 2
    layout:
      margin: "-0px 0px 0px -400px"
    cards:
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderTheme: modern
            faders:
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                .fader-value {
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderTheme: modern
            faders:
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                .fader-value {
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
        cards:
            faderHeight: 400px
            faderWidth: 200px
            borderRadius: 24px
            faderTheme: modern
            faders:
            card_mod:
              style: |
                .fader {
                  margin-left: 20px;}
                .fader-name {
                .fader-value {
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            state:
              - value: "on"
                icon: mdi:power
                color: green
              - value: "off"
                icon: mdi:power
                color: red
        card_mod:
          style: |
            ha-card {
              width: 300px;
    title: Example
You can shift the whole card left using this line margin: "-0px 0px 0px -400px"
Getting closer…
This is what it looks like on the tablet:
Questions:
  1. How do I reduce the space between the slider and the power button? I would like to lengthen the slider without pushing the power button off the Dashboard. Wouldn’t hurt my head to do away with the text so it could go to the top.
  2. How do I Spread the top two cards across the width of the dashboard?
  3. How do I change the color of the cards to the color of the background?
  4. Why are the middle and right power buttons different colors?
Here is my yaml:
  - title: Home
    sections:
      - type: grid
        cards:
            cards:
                dateFormat:
                  weekday: long
                  day: 2-digit
                  month: short
                timeFormat:
                  hour: 2-digit
                  minute: 2-digit
              - type: custom:simple-weather-card
                primary_info:
                  - wind_bearing
                  - humidity
                secondary_info:
                  - precipitation
                  - precipitation_probability
          - type: heading
            heading: null
            grid_options:
              columns: full
              rows: 1
            layout:
              margin: -70px 0px 0px 0px
              views: null
            cards:
                cards:
                    faderHeight: 200px
                    faderWidth: 120px
                    borderRadius: 24px
                    faderTheme: modern
                    faders:
                    card_mod:
                      style: |
                        .fader {
                          margin-left: 20px;}
                        .fader-name {
                        font-size: 20px !important;}
                        .fader-value {
                        font-size: 15px !important;}
                    show_name: false
                    show_icon: true
                    tap_action:
                      action: toggle
                    icon: mdi:power
                    state:
                      - value: 'on'
                        icon: mdi:power
                        color: green
                      - value: 'off'
                        icon: mdi:power
                        color: red
                card_mod:
                  style: |
                    ha-card {
                      width: 200px;
                cards:
                    faderHeight: 200px
                    faderWidth: 120px
                    borderRadius: 24px
                    faderTheme: modern
                    faders:
                    card_mod:
                      style: |
                        .fader {
                          margin-left: 20px;}
                        .fader-name {
                        .fader-value {
                    show_name: false
                    show_icon: true
                    tap_action:
                      action: toggle
                    icon: mdi:power
                    state:
                      - value: 'on'
                        icon: mdi:power
                        color: green
                      - value: 'off'
                        icon: mdi:power
                        color: red
                card_mod:
                  style: |
                    ha-card {
                      width: 200px;
                cards:
                    faderHeight: 200px
                    faderWidth: 120px
                    borderRadius: 24px
                    faderTheme: modern
                    faders:
                    card_mod:
                      style: |
                        .fader {
                          margin-left: 20px;}
                        .fader-name {
                        .fader-value {
                    show_name: false
                    show_icon: true
                    tap_action:
                      action: toggle
                    icon: mdi:power
                    state:
                      - value: 'on'
                        icon: mdi:power
                        color: green
                      - value: 'off'
                        icon: mdi:power
                        color: red
                card_mod:
                  style: |
                    ha-card {
                      width: 200px;
Thank you again
To start, are you good with deleting?
         - type: heading
            heading: null
            grid_options:
              columns: full
              rows: 1
and changing margin: -70px 0px 0px 0px
to margin: 0px 0px 0px 0px
Yes, I’ve deleted the section and changed the margin
Sorry,
I’ve got to run out.
Will have a look at this in the morning.
Appreciate all your assistance.
No problem!
Here is the correct format for your button cards
show_name: false
show_icon: true
tap_action:
  action: toggle
icon: mdi:power
state:
    - value: "on"
      styles:
        icon:
         - color: green
    - value: "off"
      styles:
        icon:
         - color: red
How is that different from what I have:
I sent you a small token of my appreciation BTW.
TTYL
Thank You! We will get it the way you want it!!
You are actually able to put all 3 sliders into one card. Let me know what you think of this
type: grid
cards:
    card_mod:
      style: |
        ha-card {
         background: #111111;
         border: none;}
    card_mod:
      style: |
        ha-card {
         border: none;}
    cards:
        cards:
            faderHeight: 200px
            faderWidth: 120px
            borderRadius: 24px
            faderTheme: modern
            faders:
              - entity_id: number.right_firmness
            card_mod:
              style: |
                ha-card {
                 background: #111111 !important;
                  border: none;}
                .fader {
                   padding: 10px 12px !important;
                .fader-name {
                .fader-value {
        cards:
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            entity: input_boolean.test
            icon: mdi:power
            styles:
              card:
                - width: 120px
                - margin-left: 40px
                - margin-top: "-20px"
                - border: none
                - background: "#111111"
            state:
              - value: "on"
                styles:
                  icon:
                    - color: green
              - value: "off"
                styles:
                  icon:
                    - color: red
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            styles:
              card:
                - width: 140px
                - border: none
            state:
              - value: "on"
                styles:
                  icon:
                    - color: green
              - value: "off"
                styles:
                  icon:
                    - color: red
            show_name: false
            show_icon: true
            tap_action:
              action: toggle
            icon: mdi:power
            styles:
              card:
                - width: 120px
                - border: none
            state:
              - value: "on"
                styles:
                  icon:
                    - color: green
              - value: "off"
                styles:
                  icon:
                    - color: red
column_span: 1
If you want the Digital Clock and Weather Card side by side, we need to reduce the font and adjsut the layout of the weather card.
