Dashboard for small wall display
I have a small (4") wall-mounted display, an NSPanel Pro, that runs the Companion app.
It’s primarily used to control the thermostat, so I have a dashboard with a Thermostat card - Home Assistant .
The problem is that the interface is difficult to see and manage from a distance. Do you know if there’s a theme or other way to make the UI more suitable for small wall-mounted displays?
