I am working on a Dashboard that utilizes the expander-card found in HACS. I can’t seem to get it to work properly. The following yaml compiles properly but when I test it, none of the objects show. I’ve tried this with devices and objects but the result is the same. The code below is an example I copied from the Github site. And I’ve tested this in both safari and chrome but neither work.
Any thoughts are appreciated! - Lee
title: Expander Test Dashboard
- title: Test
path: test
cards:
- type: custom:expander-card
child-margin-top: 0.6em
padding: 0
clear: true
title-card-button-overlay: true
title-card-clickable: true
expanded: true
title-card:
type: custom:digital-clock
dateFormat:
weekday: long
day: 2-digit
month: short
timeFormat:
hour: 2-digit
minute: 2-digit
cards:
- type: custom:simple-weather-card
entity: weather.openweathermap
primary_info:
- wind_speed
- wind_bearing
secondary_info:
- precipitation
- precipitation_probability
- type: custom:hourly-weather
icons: true
show_precipitation_probability: true
show_precipitation_amounts: true
forecast_type: hourly
num_segments: 10"
label_spacing: '1'
show_wind: speed
