Dashboard Load Error via NGINX Proxy after 2025.10.2 Update
I can no longer access the ESP Home Builder Dashboard inside HAOS after the update to 2025.10.2. The problem only happens when visiting HA via the reverse proxy. If I go directly to https://ipaddress:8123 then the dashboard will load as expected.
This was an NGINX configuration issue related to some path changes in the most recent update.
Rebuilt my HA NGINX setup, and all is working fine now.
Could you please add some more information? Which path has changed? And what do you mean with
Did you changed the nginx config?
Thank you
Hello @MXMLN
I’m sorry I didn’t note much down to be honest. I had some complex custom locations in my old NGINX config. When I faced the issues, I just switched over to a vanilla NGINX setup and it all started working fine again.
