Dashboard switch not updating from automation
I have several Lightwave RF sockets, switches etc which I switch on/off with the associated remote switch, PIR and Dusk Dawn sensor… I added some as a test to home assistant using the RFXcom integration and hardware (RFXtrx433). All the switches PIR and dusk/dawn sensors work fine when operated from the dashboard and update on the dashboard when using the physical remote.
When I create an automation, for example switch a socket on at dusk. The Dusk dawn sensor updates from off to on , showing correct state on the dashboard but the socket shows off even though it has actually switched on. The entity for the socket shows the correct states, just the dashboard does not update. Please can someone point me in the right direction as I am new to Home Assistant and just finding my feet.
Thanks.John
class37 did you find a resolution to the issue as i have exactly the same problem?
Thanks Steve
